Alan de Enfield
Everything posted by Alan de Enfield
  1. I don't suppose that those two disconnected wires have anything to do with it - do they ?
  2. Why ? Simply put weirs in their place.
  3. Don't worry - as the partnership ages you'll be lucky at once per year. Some time ago I was a 'once or twice a day man' but that fairly quicky reduced to being a 'once a week man' - now I'm very lucky if it is 'once a year'.
  4. Of course, despite your denials, boater are subsidised - do you (and the other 30,000) really think that your licence fees pays the entire costs of keeping the waterways navigable ?
  5. Yes it is not easy to insulate a boat of that size as you need to effectively buildup internal walls with insulation behind - the other, easier, alternative is to get a mooring with electric hookup and simply have an oil filled radiator - set the thermostat at a comfortable level and 'Bob's your uncle'
  6. No it doesn't. There are a number of exceptions - charging EV's being one of the,
  7. I had 40 years on the canals, and, were I still on the cut, my answer would be the same. You are happy enough to allow farmers, and others, to subsidise your boating - now its pay back time.
  8. If I had been granted an extraction licence (for which I paid heavily to get) I too would refuse - watering crops is way more important than 'some middle aged men playing about on boats'.
  9. On some boats they are simply there to assist sinking on the Thames - Summary : A bit more detail : Here it is probably apposite to quote the case of the narrow boat MINI MOO ex MARY MINT. The following is quoted verbatim from a Safety Bulletin issued by the Port of London Authority: – On the 24th August 2012, a narrow boat was delivered by road to South Dock Marina in London for a new owner. The vessel was lifted into the dock and the new owner requested to lock out of the marina as they had an overnight berth in Lime House Marina; a short distance up the River Thames. The vessel departed the lock at 17:00 with 5 adults and 1 dog aboard. As they departed the lock the lock keeper commented to them that they should have lifejackets on board as they appeared to be missing. The crew decided to continue on and left the lock with 3 adults in the aft cockpit and 2 adults in the cabin. The vessel transited directly across the river to the starboard side of the channel and then turned upriver towards Lime House Marina. Shortly into their transit the crew noted a change in the engine note and opened the engine room hatch to find the engine half submerged. All persons quickly moved to the stern to try and bail out the engine room, but were unable to cope with the ingress of water into the vessel. The engine room continued to fill with water and flooded into the main cabin, submerging the aft coaming below the water, resulting in severe flooding of the vessel which sank within 10 seconds. All of the crew and the dog entered the water without lifejackets, but were rescued by a nearby RIB and Police Launch. Marine surveyors and others concerned with narrowboats should obtain a copy of the Bulletin from the PLA and take note of its recommendations. It was noted by the PLA that the vessel had been the subject of extensive overplating. Whoever had recommended the overplating had also recommended partly blocking off the engine room air jalousie on the port side as its bottom edge was considered even then to be too near the waterline. The following Figure 1 below shows the effect of the overplating and the number of persons seated aft. The buyer of the MINI MOO bought the boat on the strength of a survey report provided by the seller. The marine surveyor concerned had estimated the height of the engine air intake jalousie from water level marks on the hull although the vessel had been out of the water for a considerable time prior to his survey. He had estimated the intake to be 200 mm above the waterline but when it measured after the salvage it was only 65 mm. The marine surveyor had covered himself with the caveat that it was an estimate only. In that particular case, when the vessel sank, no life jackets were on board and at least one person on board could not swim. The survivors were very lucky that nearby boats managed to pluck them from the water immediately. The fact that a marine surveyor’s report perhaps covers him with words such as estimated does not provide much comfort if bodies have to be pulled from the water. Figure 1: Detail of Engine Jalousie on MINI MOO Figure 1 Detail of Engine Jalousie on MINI MOO The yellow line indicates the original free board in still water this was meassured to be 65 mm. The red line indicates the waterline incurred from three people standing on the aft deck which pushed the engines jalouise below the water. The vessel was fitted with an air cooled Lister engine and, in accordance with common practice, had a ventilation jalousies cut into the topside aft to give the necessary combustion air supply for the engine. The overplating was such that the jalousie at the engine room was within 65 millimetres of the waterline. That highly dangerous situation was not helped by the presence of a small lop on the water surface. Some five people plus a dog called Gus were on board (three of them sitting aft and two in the cabin) to make the journey and, hearing unusual noises from the engine, the engine room cover was lifted and the boat was found to be rapidly taking water. The situation was made worse by all of the people on board moving aft to have a look and to try to bale the water out, thereby increasing the trim and pushing the lower edge of the jalousie 50 mm under the water. The boat rapidly filled and sank within 10 seconds but, fortunately, a nearby RIB and a police boat arrived within two minutes and all personnel, plus Gus the dog, were picked up by the police and the nearby RIB. Despite the fact that none of them were wearing life jackets and at least one of them could not swim, there were, thankfully, no fatalities although all were suffering from shock. What Gus said was not recorded. It was later said that the owner had relied on a marine survey report prepared for the previous owner and that the vessel was uninsured.
  10. Nah - I reckon he'll ask about the need for a PCA because of his change from LAs to Lithium, followed by asking for a link to a video showing how to operate a lock.
  11. Yes - there are literally dozens of warning videos on U-tuber, surprised you haven't seen them. In the USA the fire brigade issue warnings about it.
  12. Ask him his meaning of 'just bought it' ? From the work he claims to have done, and is doing, it is not a recent purchase. I was always doubtful of his honesty, & I'm afraid he now has zero credibilty, and I wouldn't trust a single word he says. Has he left the building (or just threatened)?
  13. Apparently he has had almost 2 years - & all the time he was regaling us with his adventures re negotiating a 'new build' A real "Walter" !
  14. Some years ago, when we lived in very rural Wales, the nearby village seemed to be a target for developers, there always seemed to be planning applications being submitted - these came to a halt when it turned out that there had been Otter footprints seen alongside the brook. An otter expert was called in and it turned out that the Otter appeared to have only one leg/foot, (the right fore leg). Further investigation led to a local who had carved an otter foot and was using it to make tracks wherever a planning application was being submitted. Unfortunately he only made the one-foot.
  15. Ah ............... you are thinking of the NBTA members that 'coagulate in great gatherings', remove their engines so they don't need to move and despoil the towpath and surrounding countryside.
  16. That is possibly / probably your earthing plate - not an Anode. It wou;dn't be much pont having an earthing plate that eroded away. 3.1 craft’s ground/earth protective grounding connection, provided for safety purposes, that is established by a conducting connection with the common ground/earth (potential of the earth's surface) 3.4 main grounding earthing point main point that provides connection for the DC negative conductor, AC protective grounding conductor (3.10) and bonding conductor to the craft's ground that is established by a conducting connection (intended or accidental) with the common ground (potential of the earth's surface) Note 1 to entry: It can include any conductive part of the wetted surface of the hull in permanent contact with the water, depending on the overall system design. 6.2 For craft having a fully insulated DC system, the AC protective conductor shall be connected to: a) for metallic hulled craft, the hull; b) for non-conductive hulls, the craft's external ground/earth or ground plate.
  17. Does that include 'personal care', washing, toileting etc ?
  19. It amazes me that we can end up with an entire government in which not a single one appears to have any 'running a business' experience.
