Yes typo it is a BS5
Just come back from the boat and checked clearance between pinion and starter ring face and its nearer 6mm! Manual quotes 0.79mm to just over 3mm for "smooth engagement" so probably coming at the starter ring a bit briskly, so not moving it back.
Spoke to suppliers of the starter motor and they are coming to have a look.
One thing though managed to get a good look at the starter with covers off and somebody turning the key and it appears to be engaging ok but the "clacking" noise seems to be coming from backlash on the pinion shaft and pinion gear as it turns initially on the flywheel it moves back and forward.
Didnt get this on the old one but it had a phosphor bronze pinion, not steel so maybe its just a bit louder in operation?
Anyway no damage to flywheel or pinion teeth since last year so didnt need to do any more deburring.The teeth look ok and within couple of mm from nearest to furthar away ones from the pinion when rotated with no breaks etc--normal wear and tear l guess.
When l stop engine on decompression it seems a bit smoother missing the wear points on TDC helps l guess.
Definitely looks as if new starter needs to move forward as slightly different clearance situation. Tempted to have the front casing turned down to try and get it nearer as there is plenty of teeth length on the ring.
Simon
