boatystuff Posted May 6, 2010 Report Share Posted May 6, 2010 Hello everyone today is a good day, I managed to log in after only 4 attempts. I have my BSS examination coming up and need to replace the fuel filter (its a cartridge type), because it has aplastic nut on the bottom. Can anybody recomend a suitable supplier for said item, preferably in the west mids area Thanks Tim Link to comment Share on other sites More sharing options...
WotEver Posted May 6, 2010 Report Share Posted May 6, 2010 Hi Tim, What thread is the plastic bolt? Can you find a metal one to replace it? Cheap 'n easy. Tony Link to comment Share on other sites More sharing options...
Chris-B Posted May 6, 2010 Report Share Posted May 6, 2010 If it is on a Lister Canalstar either replace the plastic drain with a 10mm bolt or fit a 751-19650 filter which does not have the drain plug on the Lucas / Cav type there is a metal drain screw available from a local diesel service centre C Link to comment Share on other sites More sharing options...
Timleech Posted May 6, 2010 Report Share Posted May 6, 2010 If it is on a Lister Canalstar either replace the plastic drain with a 10mm bolt or fit a 751-19650 filter which does not have the drain plugon the Lucas / Cav type there is a metal drain screw available from a local diesel service centre C Or from a local canal chandlery. Tim Link to comment Share on other sites More sharing options...
Chris-B Posted May 6, 2010 Report Share Posted May 6, 2010 Or from a local canal chandlery. Tim Or from us BUT I wasn't going to say that ! Link to comment Share on other sites More sharing options...
Albion Posted May 6, 2010 Report Share Posted May 6, 2010 Hello everyone today is a good day, I managed to log in after only 4 attempts. I have my BSS examination coming up and need to replace the fuel filter (its a cartridge type), because it has aplastic nut on the bottom. Can anybody recomend a suitable supplier for said item, preferably in the west mids area Thanks Tim I think you might be able to get the correct meatal drain plug from Midland Sw...sorry Chandlers. It's worth a phone call if you can quote the type of filter and housing. Roger Link to comment Share on other sites More sharing options...
wirren Posted May 6, 2010 Report Share Posted May 6, 2010 (edited) Hi, I cut the top off a Lyons Golden Syrup tin. The tin fits snugly over the filter with a 3" hose clip !! The plastic bit is now protected from the surrounding area. Not had the test yet but I am confident there won't be a problem. Edited May 6, 2010 by wirren Link to comment Share on other sites More sharing options...
casper ghost Posted May 6, 2010 Report Share Posted May 6, 2010 Hi,I cut the top off a Lyons Golden Syrup tin. The tin fits snugly over the filter with a 3" hose clip !! The plastic bit is now protected from the surrounding area. Not had the test yet but I am confident there won't be a problem. I'm not confident your idea will pass...unless the examiner doesn't look... Link to comment Share on other sites More sharing options...
boatystuff Posted May 7, 2010 Author Report Share Posted May 7, 2010 Thanks everybody for the information Tim Link to comment Share on other sites More sharing options...
