Don't Neglect Your Integral Water Tank
matty40s
Thank you everybody especially chewbakka who provided the blow by blow account on how to proceed. I will now lift the lid, evict anything that is still alive, pump out the water, remove the debris and rust, coat with Vactan as the primer and Armourguard PW as the topcoat.
Thank You
Thank You
Armourguard ST is the better primer to use with Armourguard PW. If the rust is not too deep then spend more time getting rid of it. If you can get to 90% bare metal then I would use the ST directly and forget the Vactan. ST is designed to stick directly to steel (which it certainly does).
............Dave
