Recommend pressure switch for fresh water system
Ssscrudddy
I turned on my tap yesterday & water came out, then it stopped, the water pump didnt kick in (& there was water in the tank). After looking around I found what I believe to be an external pressure switch next to the water pump, so I hit it, & hey presto the pump started working.
I checked my taps & indeed I had water pressure until it stopped again, & the pump didnt kick in, & so I hit the pressure switch again & it worked again.
Rinse & repeat.
So it seems my pressure switch no longer works from turning the tap on until I hit the damn thing.
I shall try & clean it out see if that makes a difference, but I'm not practical with stuff like this (give me a computer to pull apart any day, so much easier).
So I may need a new 1, so any recommendations please.
The pump itself has 30 psi written on it.
I second Square D if you can find one otherwise I think Whale make one in a white plastic case but it uses a micro switch like the one in the pump so I would add a standard automotive 20 amp relay so the new switch only carries the relay coil current and the relay contact switch the pump.
The pump itself is Sureflow 39010213. 30 psi. The pressure switch is a Square D.
The pressure switch seems to be working properly again now. But I think I'll order a spare anyway. Trouble is I havent got a clue what to order, there's loads to chose from.
