Hi all.
I'm looking at a 100amp 12v second alternator for a BMC 1.8.
Would this amperage Alternator be ok for the engine?
Suggestions welcome.
D
I suspect that a 1.8 will drive both easily BUT if using only one belt don't expect it to last long and even if using two belts remember that taking 2 -4Kw off the engine will restrict the power available for propulsion.
You say second alternator, so are presumably also going to be retaining an existing lower powered on?
What current is that, and do you plan to use it just for starter battery charging.
I think the issue with ones as big as 100 amps will not be so much the load they place on the engine, but coming up with pulleys and belts to drive it adequately.
Generally people seem to thing only up to about 70/80 amps is really sound with a standard 10mm "V" belt.
Edited by alan_fincher
Yes, I have a 30amp standard alternator at present. I have a triple crankshaft pulley from Calcutt boats, so each would be driven separately.
I'd heard that 70-80 should be around max for a 10mm V. But I've also read that a 100amp alternator won't crank nearly that amount at idle/low revs.
In case it makes any difference, I have a 180amp sterling alt-batt charger. I'd quite like to use as much of that 180amps as possible!
Cheers
Sorry, make that 130 amp alt-batt charger
Can you use two of the slots on the Calcutt pulley for a matched pair of Vee belts for the big alt.
Good idea that man!!
