bag 'o' bones Posted May 23, 2011 Author Report Share Posted May 23, 2011 (edited) Can you get at the back of the socket with a multimeter to read what voltage is actually going into the thing? Tony My next job - problem is the boat is an hours drive away so will have to wait a while. Also i'm going to try powering the TV off the car accessory socket and see if it creates the same heating effect in the brick. Edited May 23, 2011 by bag 'o' bones Link to comment Share on other sites More sharing options...
WotEver Posted May 24, 2011 Report Share Posted May 24, 2011 Also i'm going to try powering the TV off the car accessory socket and see if it creates the same heating effect in the brick. Good test Tony Link to comment Share on other sites More sharing options...
Nickhlx Posted May 24, 2011 Report Share Posted May 24, 2011 Is the TV REALLY drawing what it claims to be ? Or perhaps more and overloading it ? Nick Link to comment Share on other sites More sharing options...
OldGoldy Posted May 24, 2011 Report Share Posted May 24, 2011 so one would expect the unit to run as least as cool as a lap-top mains power brick? ???? some of these run very hot. Link to comment Share on other sites More sharing options...
Chalky Posted May 24, 2011 Report Share Posted May 24, 2011 Hot for power electronics and hot by touch can be very different. A regulator may be designed to run at 60deg+ all day and be reliable and happy doing it. It would be hot to the touch, but be ok. Alternatively it may fail at not much hotter than room temperature. Ensure all of its air vents are clear and that air can circulate round it - it may be that it's not able to ventelate properly. Managing heat is key to electronics reliability and also their power handling capability. Link to comment Share on other sites More sharing options...
bag 'o' bones Posted May 25, 2011 Author Report Share Posted May 25, 2011 ???? some of these run very hot. The mains lap top bricks I use don't get anywhere near the temperature of the 12 volt regulator. Thing you would have thought converting 230 ac into 19 volt would produce more heat. I could understand the heating effects if the 12 volt brick was having to convert very diffrent voltages. Dunno i'm not that savvy when it comes to electrickery. Hot for power electronics and hot by touch can be very different. A regulator may be designed to run at 60deg+ all day and be reliable and happy doing it. It would be hot to the touch, but be ok. Alternatively it may fail at not much hotter than room temperature. Ensure all of its air vents are clear and that air can circulate round it - it may be that it's not able to ventelate properly. Managing heat is key to electronics reliability and also their power handling capability. Its a sealed plastic brick. Fair comment though. Link to comment Share on other sites More sharing options...
Pretty Funked Up Posted May 26, 2011 Report Share Posted May 26, 2011 In a faglighter socket. Crap connectors them, get hot. It certainly sounds like a bad connection somewhere. I'd start by eliminating the above. Try swapping it for a chunky chocolate box style connector as a test. Link to comment Share on other sites More sharing options...
bag 'o' bones Posted May 27, 2011 Author Report Share Posted May 27, 2011 Been back to the boat to day to take some voltage readings: At the distribution board: 12.4 volts batteries part discharged 14.4 with engine running on tick over 12.9 volts half an hour later after charging and engine off. At the socket: 12.44 part discharged. 12.90 after charging In other exactly what you would expect from a basic 12 volt system. Tried the tv off the car 12 volt socket and it was just as hot. My conclusion is the voltage drop is negiable and that the brick is a bit cheap and probabaly not a particularly efficient switch mode if at all. Maybe its a linear converter masquerading as a switch mode. No way of checking without destroying the case. Link to comment Share on other sites More sharing options...
Justme Posted May 27, 2011 Report Share Posted May 27, 2011 You need to test the voltage whilst it is in use. Link to comment Share on other sites More sharing options...
WotEver Posted May 27, 2011 Report Share Posted May 27, 2011 (edited) My conclusion is <snip> the brick is a bit cheap... Agreed. Either that or faulty. Tony Edited May 27, 2011 by WotEver Link to comment Share on other sites More sharing options...
