colin loach Posted August 28, 2010 Report Share Posted August 28, 2010 Hi all, I want to fit a pressure gauge to my central heating 15mm pipe work but i cant find a gauge only they seem to be prv which i don't need. dose anyone have any surjections. Colin. Link to comment Share on other sites More sharing options...
Paul Evans Posted August 28, 2010 Report Share Posted August 28, 2010 I Googled "central heating"+"pressure gauge" and came up with a number of hits. Most of those I looked at had 1/4" or 1/2" fittings but I am sure you could find a suitable connection for your 15mm pipework. Here are some examples: pressuregauge.co.uk Thermosense Flamco Flexon Link to comment Share on other sites More sharing options...
Timleech Posted August 28, 2010 Report Share Posted August 28, 2010 You don't say what sort of pressure you need to measure, but I imagine it'll be fairly low. If so ebay link along with another ebay link gets you to 15mm. There might be such a thing as a 15mm tee with 1/4" branch, or more likely a 1/2" branch which can then be reduced, which could be neater depending on whether the gauge is to sit on your pipework or to be remote mounted. Gauges should strictly screw into special fittings, but for your purposes a parallel thread with the right sealant will probably be OK. Tim Link to comment Share on other sites More sharing options...
colin loach Posted August 28, 2010 Author Report Share Posted August 28, 2010 Thanks for that all i need to do now is find something to fit the gauge to. You don't say what sort of pressure you need to measure, but I imagine it'll be fairly low. If so ebay link along with another ebay link gets you to 15mm. There might be such a thing as a 15mm tee with 1/4" branch, or more likely a 1/2" branch which can then be reduced, which could be neater depending on whether the gauge is to sit on your pipework or to be remote mounted. Gauges should strictly screw into special fittings, but for your purposes a parallel thread with the right sealant will probably be OK. Tim Thats just what i am looking for. thanks Colin. Link to comment Share on other sites More sharing options...
Gibbo Posted August 28, 2010 Report Share Posted August 28, 2010 guage gauge Link to comment Share on other sites More sharing options...
Keeping Up Posted August 28, 2010 Report Share Posted August 28, 2010 guage gauge Smart arse Link to comment Share on other sites More sharing options...
