onionbargee Posted August 16, 2010 Report Share Posted August 16, 2010 Can anyone give me the lowdown on setting up a hydraulic drive using gear motor and pump 30cc / 60cc, i need to know the layout of pipes, a diagram would be good, size of resevoir ect, and whether to consider using a vane motor. Link to comment Share on other sites More sharing options...
Tony Brooks Posted August 16, 2010 Report Share Posted August 16, 2010 Can anyone give me the lowdown on setting up a hydraulic drive using gear motor and pump 30cc / 60cc, i need to know the layout of pipes, a diagram would be good, size of resevoir ect, and whether to consider using a vane motor. Now you are asking about the layout of the pipes I can help with that. There is a generic digram in the drive-line section of the maintenance notes but some motors require another small bleed off pipe that simply returns to the reservoir. Link to comment Share on other sites More sharing options...
ditchcrawler Posted August 16, 2010 Report Share Posted August 16, 2010 Can anyone give me the lowdown on setting up a hydraulic drive using gear motor and pump 30cc / 60cc, i need to know the layout of pipes, a diagram would be good, size of resevoir ect, and whether to consider using a vane motor. I think that AR Peachment of Brundall do this type of hydraulic set up Link to comment Share on other sites More sharing options...
