bag 'o' bones Posted November 27, 2009 Report Share Posted November 27, 2009 Here's our first attempt at fitting a stove: Fitting a stove in pictures Quick mock up of stove sitting on its hearth. Just to make everything fits and looks right. Hearth covering cut from a 2' x 2' real slate tile. Flue pipe template Tacked up to check flue pipe angles for for fit - no skewif flue pipes on this boat! Arc welding the flue pipe Hole cut in roof and bolt holes drilled Flue collar fitted using 'blind bolts' Bolted up Flue fitted and painted. Fitting 'asbetoslux' fire proof material. Tiled Gravity central heating pipework fitted Chimney fitted (Also hand made) This chimney was stolen not long after so be warned if its on your roof we'll be asking for it back! Make fire and finished. Link to comment Share on other sites More sharing options...
deletedaccount Posted November 27, 2009 Report Share Posted November 27, 2009 (edited) Nice work mate. I'm interested in the dimensions of the hearth. Is it a 2x2 bit with the corner cut off? I'm trying to work it out for mine. Edited November 27, 2009 by deletedaccount Link to comment Share on other sites More sharing options...
bag 'o' bones Posted November 28, 2009 Author Report Share Posted November 28, 2009 Nice work mate. I'm interested in the dimensions of the hearth. Is it a 2x2 bit with the corner cut off? I'm trying to work it out for mine. Yes. Except the tiling around the perimeter. The BSS examiner thought that a little extra hearth width in front of the door would be better, therefore we built the tiled upturn to prevent cinders from dropping onto the floor. Good constructive critism we thought. Upon completion the set-up passed the BSS with flying colours. Link to comment Share on other sites More sharing options...
GSer Posted November 28, 2009 Report Share Posted November 28, 2009 Did you bolt the stove down at all? Link to comment Share on other sites More sharing options...
bag 'o' bones Posted November 28, 2009 Author Report Share Posted November 28, 2009 (edited) Did you bolt the stove down at all? Yes. Made some simple L shaped brackets at the rear. Proper ones were about 15 quid each! If you look at the last picture you can just make them out as they have not been painted yet. Edited November 28, 2009 by bag 'o' bones Link to comment Share on other sites More sharing options...
Dekko Posted November 28, 2009 Report Share Posted November 28, 2009 Really useful.. hope to get down to install a stove/boiler next month so well timed. What make is the stove? Many thanks for taking the time to take the pics. Link to comment Share on other sites More sharing options...
bag 'o' bones Posted November 28, 2009 Author Report Share Posted November 28, 2009 Really useful.. hope to get down to install a stove/boiler next month so well timed.What make is the stove? Many thanks for taking the time to take the pics. It's an Aarrow 'Becton Bunny' 5. The smallest model they make (I think) Impressed with the quality - the main body is steel so there less prone to cracking - and the heat performance. You don't need a lot of fuel to get the whole boat (48') warm. Its connected to a gravity central heating hot water system which works very well. The hot water loop takes a while to get going though simply because of the restrictive coil in the calorifier so we fitted a small brushless pump just to give it a kick. The radiator loop going the whole length of the boat is 22mm so flows very well. If you haven't bough a calorifier yet might wrth trying to find one with 22mm coils. Link to comment Share on other sites More sharing options...
Old Son Posted November 28, 2009 Report Share Posted November 28, 2009 Was the flue collar a special? Most of the ones I have seen for sale are not angled. Yours looks very neat. Where did you buy it? Link to comment Share on other sites More sharing options...
bag 'o' bones Posted November 28, 2009 Author Report Share Posted November 28, 2009 (edited) Was the flue collar a special? Most of the ones I have seen for sale are not angled. Yours looks very neat. Where did you buy it? The photo is a bit deceiving. Its a standard collar ground on one side to fit the roof profile. On our boat the roof curvature is quite pronounced so even after shaving off as much as we dared the other side needed a bit of packing to get the chimmney to sit straight. To finish the resiulting gap was filled using chemical metal which after a year is showing signs of cracking with the expansion and contraction. Still having said that most chimmney collars i've seen crack their paint at the seams so I don't think it will cause too much of a problem. I think in the future we might get a new collar cast properly. One thing I hate is chimmneys that stick out at a lop sided angle! Edited November 28, 2009 by bag 'o' bones Link to comment Share on other sites More sharing options...
Frankieboy Posted December 5, 2010 Report Share Posted December 5, 2010 The photo is a bit deceiving. Its a standard collar ground on one side to fit the roof profile. On our boat the roof curvature is quite pronounced so even after shaving off as much as we dared the other side needed a bit of packing to get the chimmney to sit straight. To finish the resiulting gap was filled using chemical metal which after a year is showing signs of cracking with the expansion and contraction. Still having said that most chimmney collars i've seen crack their paint at the seams so I don't think it will cause too much of a problem. I think in the future we might get a new collar cast properly. One thing I hate is chimmneys that stick out at a lop sided angle! Where did you get the chimney from? we're fitting the same stove but all chimneys seem to be 6" ones and I think the collar will be 4 3/4 inch unless I've been mis informed about the collar sizing. Link to comment Share on other sites More sharing options...
nb Innisfree Posted December 5, 2010 Report Share Posted December 5, 2010 Actually searching for a genuinely straight collar proved fruitless for us, eventually had to settle for a slightly angled one from Midland Chandlers, they swore blind it was straight but I bought it anyway despite their insistence, amazing the 'eye' a lot of people seem to have. Link to comment Share on other sites More sharing options...
rjasmith Posted December 5, 2010 Report Share Posted December 5, 2010 Where did you get the chimney from? we're fitting the same stove but all chimneys seem to be 6" ones and I think the collar will be 4 3/4 inch unless I've been mis informed about the collar sizing. He made his own chimney! (see earlier in the thread). (and then had it stolen!) I thought Midland Chandlers did matching sets of collars and chimneys - certainly I got mine from them a while back. Got Colecraft to modify them while they were building the shell so they would fit the roof camber This was done by welding in a fillet of steel and grinding smooth. They were quite good but I found I needed to do a bit more grinding after delivery to get an even better fit! Richard Link to comment Share on other sites More sharing options...
