oggie Posted April 8, 2009 Report Share Posted April 8, 2009 Is this correct. And if so is this an RCBO as Chris W suggests. Thanks for all your help. Bear with me will get my head screwed on straight before much longer. Bob Link to comment Share on other sites More sharing options...
chris w Posted April 9, 2009 Report Share Posted April 9, 2009 (edited) Yes it is an RCBO. It is a 30mA RCD coupled with a 16A MCB. It is IDENTICAL to mine. Worry over Chris Edited April 9, 2009 by chris w Link to comment Share on other sites More sharing options...
oggie Posted April 9, 2009 Report Share Posted April 9, 2009 Yes it is an RCBO. It is a 30mA RCD coupled with a 16A MCB. It is IDENTICAL to mine. Worry over Chris Many thanks for all your help, have learnt quite a bit these last few days, goes to show your never to old to learn. Look forward to disscussing next topic, wife don't know yet but thinking of having an immersion heater fitted into my hot water tank. to save running engine up whilst sat in the marina. Regards Bob. Link to comment Share on other sites More sharing options...
chris w Posted April 9, 2009 Report Share Posted April 9, 2009 To preempt your discussion on immersion heaters, the formula for calculating heating times is as follows: T (hours) = V x C x 1.2 / P where: V = volume of water to be heated in litres C = temperature over which the water needs to be heated in degrees C P = Immersion heater power in Watts. eg: to heat 60 litres from 10degC to 60degC (ie: 50degC difference) with a 1KW immersion heater will take: 60 x 50 x 1.2 / 1000 = 3.6 hours ie: a pretty long time. Chris Link to comment Share on other sites More sharing options...
bottle Posted April 9, 2009 Report Share Posted April 9, 2009 and use 3.6 units of electricity. Cost per unit varies but will be in the region of 15p per unit so, cost = 3.6*15 = 54p Link to comment Share on other sites More sharing options...
GUMPY Posted April 9, 2009 Report Share Posted April 9, 2009 and use 3.6 units of electricity. Cost per unit varies but will be in the region of 15p per unit so, cost = 3.6*15 = 54p So to heat a calorifier with the engine takes how long? My narrowboat from memory used to take just under hour and would only do it if the engine was in gear..............otherwise it took hours On that boat 1 Litre diesel per hour = 60p so about the same On Parglena 4litres of diesel per hour = £2.40 so much cheaper using the immersion. J Link to comment Share on other sites More sharing options...
Justme Posted April 9, 2009 Report Share Posted April 9, 2009 So to heat a calorifier with the engine takes how long?My narrowboat from memory used to take just under hour and would only do it if the engine was in gear..............otherwise it took hours On that boat 1 Litre diesel per hour = 60p so about the same On Parglena 4litres of diesel per hour = £2.40 so much cheaper using the immersion. J I think I might be missing the point but arnt calorifiers meant to take WASTE heat from using the engine for ANOTHER PURPOSE to heat water not to be used JUST to heat water? Justme Link to comment Share on other sites More sharing options...
GUMPY Posted April 9, 2009 Report Share Posted April 9, 2009 (edited) I think I might be missing the point but arnt calorifiers meant to take WASTE heat from using the engine for ANOTHER PURPOSE to heat water not to be used JUST to heat water? That's the theory, but I have seen lots of boats that do not have any other way of heating their water, then if they want hot water whilst moored they have to run the engine or fit a secondary means of water heating. Edited April 9, 2009 by idleness Link to comment Share on other sites More sharing options...
