nigel fryer Posted March 12, 2009 Report Share Posted March 12, 2009 We have a problem with rusty water We can see through the filler inlet that the sides of the tank are rather rusty I am going to have to drain it all down ,dry it and re black it Has anyone ever FIBRE GLASSED their WATER tank !! Ps the new inverter is working fine ! with no problems . Many thanks Nige Link to comment Share on other sites More sharing options...
canalchris Posted March 12, 2009 Report Share Posted March 12, 2009 We have a problem with rusty water We can see through the filler inlet that the sides of the tank are rather rusty I am going to have to drain it all down ,dry it and re black it Has anyone ever FIBRE GLASSED their WATER tank !! Ps the new inverter is working fine ! with no problems . Many thanks Nige [/Have you seen the adds for tank liners in the canal glossies ? quote] Link to comment Share on other sites More sharing options...
Ex- Member Posted March 13, 2009 Report Share Posted March 13, 2009 Tank liner is the best solution IMO should last donkeys years, you can get them made to measure I believe but will cost. Having to repaint a water tank every few years is a nightmare scenario IMO. And the initial cost will pay for it's self in the long run. In a way they're as good as a S/S tank as you can probably use water from these as drinking water if made with the correct material. Link to comment Share on other sites More sharing options...
RLWP Posted March 13, 2009 Report Share Posted March 13, 2009 Tank liner is the best solution IMO should last donkeys years, you can get them made to measure I believe but will cost. Having to repaint a water tank every few years is a nightmare scenario IMO. And the initial cost will pay for it's self in the long run. In a way they're as good as a S/S tank as you can probably use water from these as drinking water if made with the correct material. We have a rubber tank in the place the hull tank was AND We cleaned and painted the tank before putting the rubber one in Richard You don't get away with it that easy... Link to comment Share on other sites More sharing options...
Ex- Member Posted March 13, 2009 Report Share Posted March 13, 2009 We cleaned and painted the tank before putting the rubber one in Of course A good solution following cleaning out prior to liner is using Waxoyl instead of usual blacking. Between the liner and steel sides will condensate, waxoyl will stand up to this much longer than the usual blacking, depending on the fit of the liner, if made to measure it will likely stick to the waxoyl so when the liner partially empties it will stay stuck to the steel sides avoiding any gaps that would condensate, as Waxoly has a tacky finish and never fully dries out. Link to comment Share on other sites More sharing options...
twocvbloke Posted March 13, 2009 Report Share Posted March 13, 2009 Of course A good solution following cleaning out prior to liner is using Waxoyl instead of usual blacking. Between the liner and steel sides will condensate, waxoyl will stand up to this much longer than the usual blacking, depending on the fit of the liner, if made to measure it will likely stick to the waxoyl so when the liner partially empties it will stay stuck to the steel sides avoiding any gaps that would condensate, as Waxoly has a tacky finish and never fully dries out. Well, waxoyl is the saviour of many a 2CV, so it is very thoroughly recommended... Link to comment Share on other sites More sharing options...
