colin loach Posted February 3, 2009 Report Share Posted February 3, 2009 my bss has just run out but my river licence don't expire until September, so can I use my boat. Colin. Link to comment Share on other sites More sharing options...
carlt Posted February 3, 2009 Report Share Posted February 3, 2009 There is no legal requirement to have a Boat Safety Certificate so I would say boat away. Link to comment Share on other sites More sharing options...
colin loach Posted February 3, 2009 Author Report Share Posted February 3, 2009 if i use the boat without a bss will it effect my insurance Link to comment Share on other sites More sharing options...
AlanJ Posted February 3, 2009 Report Share Posted February 3, 2009 if i use the boat without a bss will it effect my insurance I can only suggest that you check your insurance to see if the BSS is a specific condition of insurance. Some insurance policies may require it, others might not Link to comment Share on other sites More sharing options...
colin loach Posted February 3, 2009 Author Report Share Posted February 3, 2009 I can only suggest that you check your insurance to see if the BSS is a specific condition of insurance.Some insurance policies may require it, others might not thanks Alan. Link to comment Share on other sites More sharing options...
Timleech Posted February 3, 2009 Report Share Posted February 3, 2009 if i use the boat without a bss will it effect my insurance If there's anything that would obviously fail, that might be taken as a sign of a lack of proper maintenance. Insurers love to find excuses for not paying. My car caught fire some years ago, although the fire was put out fairly quickly the car was a write off because of its age. When the insurance assessor came to look at it, the very first thing he did was get out his tread gauge & check the tyres, he was looking for any sign of poor maintenance. As it happens, I was seriously pi**ed off about the fire largely because I had put 4 new tyres on the car only a few days before, & ended up buying it back from the insurers just to get the tyres back. Tim Link to comment Share on other sites More sharing options...
colin loach Posted February 3, 2009 Author Report Share Posted February 3, 2009 If there's anything that would obviously fail, that might be taken as a sign of a lack of proper maintenance. Insurers love to find excuses for not paying. My car caught fire some years ago, although the fire was put out fairly quickly the car was a write off because of its age. When the insurance assessor came to look at it, the very first thing he did was get out his tread gauge & check the tyres, he was looking for any sign of poor maintenance. As it happens, I was seriously pi**ed off about the fire largely because I had put 4 new tyres on the car only a few days before, & ended up buying it back from the insurers just to get the tyres back. Tim Tim the boat is a sail away and not yet completed but useable it conformity just expired Link to comment Share on other sites More sharing options...
Cosmic Posted September 13, 2009 Report Share Posted September 13, 2009 On a similar theme, let's say I buy a boat with, say, 6 months to run on its BSC and then get it tested to find out what work needs doing. If it fails the test, does this invalidate the existing test or can I still rely on the existing certificate? It sounds as if there may be two different answers, one for licensing and a different one for insurance purposes. Also, could a seller do this - have a boat tested while its old certificate is still valid and then decide that it's not worth fixing all its faults and sell it with the old certificate? Link to comment Share on other sites More sharing options...
Radiomariner Posted September 13, 2009 Report Share Posted September 13, 2009 On a similar theme, let's say I buy a boat with, say, 6 months to run on its BSC and then get it tested to find out what work needs doing. If it fails the test, does this invalidate the existing test or can I still rely on the existing certificate? It sounds as if there may be two different answers, one for licensing and a different one for insurance purposes. Also, could a seller do this - have a boat tested while its old certificate is still valid and then decide that it's not worth fixing all its faults and sell it with the old certificate? The BSS allows for a certification renewal to be made up to two months before the termination of the existing certificate and the new cert dated to end 4 years from the end of the original cert. This is to allow boat owners to rectify any defects before the certificate expires. Therefore, logically for two months the old certificate can still valid after failing to attain a new cert. However as mentioned in an earlier post, insurance companies are quick to find reasons for avoiding paying out. Examination failures are recorded as well as the passes, it is very easy for the insurance companies to check out, probably the very first check they make. On your last point I am afraid it can be done, but the vendor will then be guilty of non disclosure. (BSS records will be evidence). If the boat is found to be dangerous a notice will be posted on the boat and if necessary authorities informed. The vendor is in breach of law if he removes the notice without rectifying the defects. Having said all this of course it is not to say that it will not happen. I do not believe that the BSC should be considered in the sale/purchase of a boat as, like your car MOT test, the Certificate only relates the condition of the boat on the day of the examination, and it covers only a minimum safety standard. A surveyor's report should cover such standards, and much much more. Link to comment Share on other sites More sharing options...
Smelly Posted September 13, 2009 Report Share Posted September 13, 2009 There's a requirement built into the '95 BWA that requires the boat meets a prescribed standard before a licence is granted. Once the licence is granted it needs to be revoked so in the absence of revocation action I reckon you'll be okay. Link to comment Share on other sites More sharing options...
Cosmic Posted September 14, 2009 Report Share Posted September 14, 2009 Thanks for that, people. I suppose what I'd want is for a BSS examiner to do an informal report to say what would happen if it were to be tested. That way, pass or fail, the result isn't actually recorded, but I'd still get to know in advance what work is needed. Does such a thing exist? Link to comment Share on other sites More sharing options...
Smelly Posted September 14, 2009 Report Share Posted September 14, 2009 Thanks for that, people. I suppose what I'd want is for a BSS examiner to do an informal report to say what would happen if it were to be tested. That way, pass or fail, the result isn't actually recorded, but I'd still get to know in advance what work is needed. Does such a thing exist? Friendly examiners might not charge a re-test fee... Link to comment Share on other sites More sharing options...
