colin loach Posted October 7, 2008 Report Share Posted October 7, 2008 i have 3 domestic batteries and 1 starter battery. I have connected all negatives to the engine everything is working ok, but when I disconnected the domestic negative buzz bar I still had my led lights working. I traced this back to the earth on the stereo Arial linking both domestic and starter batteries together via the shell, is this normal?. Thanks Colin Link to comment Share on other sites More sharing options...
Chris Pink Posted October 7, 2008 Report Share Posted October 7, 2008 i have 3 domestic batteries and 1 starter battery. I have connected all negatives to the engine everything is working ok, but when I disconnected the domestic negative buzz bar I still had my led lights working. I traced this back to the earth on the stereo Arial linking both domestic and starter batteries together via the shell, is this normal?. Thanks Colin It's not good, in the event of a fault - as illustrated by your action - all the DC return current will go through the aerial cable screen, ok for LED light level current but not for anything more powerful - there is the potential for the aerial lead to get rather hot. You should isolate the aerial lead from the hull, either by sitting the aerial on an insulated mount or by modifying the cable near the radio. Link to comment Share on other sites More sharing options...
colin loach Posted October 7, 2008 Author Report Share Posted October 7, 2008 I can see what you mean but will this effect my reception. Link to comment Share on other sites More sharing options...
Keeping Up Posted October 7, 2008 Report Share Posted October 7, 2008 Unfortunately this is very common, I have spent a long time tracking down and curing spurious earths which, as Chris says, could potentially be a source of danger. If your aerial is a "car radio" type, it will be difficult to isolate it from the hull (and even if you do, you may get noisy radio reception), so it is easier to isolate the outer sheath of the aerial cable near the radio. I was able to peel back the plug itself and insert a small capacitor in series with the sheath, but it was a fiddly job and it may be easier to cut the cable and use a 'chocolate block' connector to hold the wires and capacitor (something like 1000pF from this range would do). As well as two radio aerials and the TV aerial, I also found spurious earth connections in two exterior bulkhead lights and the two navigation lights. Most unsatisfactory! Link to comment Share on other sites More sharing options...
colin loach Posted October 7, 2008 Author Report Share Posted October 7, 2008 bare in mind I have two alternators dose this make any difference Link to comment Share on other sites More sharing options...
colin loach Posted October 7, 2008 Author Report Share Posted October 7, 2008 Unfortunately this is very common, I have spent a long time tracking down and curing spurious earths which, as Chris says, could potentially be a source of danger. If your aerial is a "car radio" type, it will be difficult to isolate it from the hull (and even if you do, you may get noisy radio reception), so it is easier to isolate the outer sheath of the aerial cable near the radio. I was able to peel back the plug itself and insert a small capacitor in series with the sheath, but it was a fiddly job and it may be easier to cut the cable and use a 'chocolate block' connector to hold the wires and capacitor (something like 1000pF from this range would do). As well as two radio aerials and the TV aerial, I also found spurious earth connections in two exterior bulkhead lights and the two navigation lights. Most unsatisfactory! dose spurious earths cause any damage in normal circumstances Link to comment Share on other sites More sharing options...
Chris Pink Posted October 7, 2008 Report Share Posted October 7, 2008 (edited) dose spurious earths cause any damage in normal circumstances Easy answer: Yes, very much so, could be seen as one of the major causes of fire in 12V systems. More complex answer: depends on what you mean by 'normal', damage will only be caused when another fault occurs, for instance if you had disconnected the main supply -ve or it broke and then a water pump or inverter was switched on the whole current for that device would return through the 'spurious earth' connection which is not designed to handle it. Whereas your aerial lead could probably handle a fair amount without catching fire there are many other scenarios where this wouldn't be the case. And you have illustrated one of the major problems; if you don't know which way your current returns, you can't isolate it and fault finding becomes a factor more complicated. Edited October 7, 2008 by Chris Pink Link to comment Share on other sites More sharing options...
colin loach Posted October 7, 2008 Author Report Share Posted October 7, 2008 that all makes sense. so back to the capacitor, what about using an inline fuse. how dose the capacitor work. Link to comment Share on other sites More sharing options...
chris w Posted October 7, 2008 Report Share Posted October 7, 2008 (edited) A capacitor will pass ac currents but not dc so the direct earth due to the aerial lead is broken, but the (ac) radio signals will still pass through the capacitor. The capacitor's ability to pass ac currents is dependent on the capacitor's value and the frequency of the ac one is trying to pass. Allann's suggestion of around 1000nF is quite correct as at FM frequencies (say 100MHz), the impedance of the capacitor (its "resistance" in layman's terms) is less than 2 milliohms. At MW frequencies (say 500KHz) the impedance increases to about 0.3 ohms. Chris Edited October 7, 2008 by chris w Link to comment Share on other sites More sharing options...
colin loach Posted October 7, 2008 Author Report Share Posted October 7, 2008 A capacitor will pass ac currents but not dc so the direct earth due to the aerial lead is broken, but the (ac) radio signals will still pass through the capacitor. The capacitor's ability to pass ac currents is dependent on the capacitor's value and the frequency of the ac one is trying to pass. Allann's suggestion of around 1000pF is quite correct as at FM frequencies (say 100MHz), the impedance of the capacitor (its "resistance" in layman's terms) is less than 2 milliohms. At MW frequencies (say 500KHz) the impedance increases to about 0.3 ohms. Chris hope you don't mind just one more question. you mention mw is it the same for fm. many thanks colin Link to comment Share on other sites More sharing options...
chris w Posted October 7, 2008 Report Share Posted October 7, 2008 hope you don't mind just one more question. you mention mw is it the same for fm. many thanks colin Read through my post again Colin. I mentioned both FM and MW Chris Link to comment Share on other sites More sharing options...
colin loach Posted October 7, 2008 Author Report Share Posted October 7, 2008 sorry missed that bit. there are all sorts of capacitors have you got a picture of the sort I should buy from maplin. thanks. Link to comment Share on other sites More sharing options...
chris w Posted October 7, 2008 Report Share Posted October 7, 2008 (edited) sorry missed that bit. there are all sorts of capacitors have you got a picture of the sort I should buy from maplin. thanks. Allan gave a link to the Maplin site in his original post above. Here it is again for convenience http://www.maplin.co.uk/Module.aspx?ModuleNo=304 The type you need is Part No.WX68Y @ £0.11 Chris Edited October 7, 2008 by chris w Link to comment Share on other sites More sharing options...
Guest TerryL Posted October 7, 2008 Report Share Posted October 7, 2008 i have 3 domestic batteries and 1 starter battery. I have connected all negatives to the engine everything is working ok, but when I disconnected the domestic negative buzz bar I still had my led lights working. I traced this back to the earth on the stereo Arial linking both domestic and starter batteries together via the shell, is this normal?. Thanks Colin Perhaps I'm missing something here but why would you want to disconnect the negative bus bar only and create a problem? Keep all negatives connected and switch off only on the positive and no problem! Link to comment Share on other sites More sharing options...
chris w Posted October 7, 2008 Report Share Posted October 7, 2008 Perhaps I'm missing something here but why would you want to disconnect the negative bus bar only and create a problem? Keep all negatives connected and switch off only on the positive and no problem! He's not creating a problem, he's identified an existing problem which is real but normally hidden. The capacitor will preclude the problem ever becoming an issue. It's a safety thing. Chris Link to comment Share on other sites More sharing options...
chris w Posted October 7, 2008 Report Share Posted October 7, 2008 BTW, I mistakenly read Allan's original post as a suggestion of a 1000nF capacitor and did my calculations on that basis. In fact Allan suggested a 1000pF capacitor. IMHO, I feel a 1000pF will cause problems on MW as it will have too high an impedance (300 ohms). I believe (with all due respect to Allan) that a 1000nF would be a better choice. In fact anything in the range of 100nF to 1000nF should work fine. Chris Link to comment Share on other sites More sharing options...
colin loach Posted October 7, 2008 Author Report Share Posted October 7, 2008 thanks for all your time and information, its been a great help. my problems started when I turned off the cut off switch to leave the boat and noticed the stereo stayed on for about 3 seconds. I checked the volt meter and saw the voltage was draining down slowly. so one by one I disconnected each appliance, and that is when I noticed that my lights were still on and everything was disconnected. you know the rest.i think my inverters some our although off are storing a small amount of current for a short while, because when I disconnected them the volt metre dropped straight away. Link to comment Share on other sites More sharing options...
chris w Posted October 7, 2008 Report Share Posted October 7, 2008 thanks for all your time and information, its been a great help. my problems started when I turned off the cut off switch to leave the boat and noticed the stereo stayed on for about 3 seconds. I checked the volt meter and saw the voltage was draining down slowly. so one by one I disconnected each appliance, and that is when I noticed that my lights were still on and everything was disconnected. you know the rest.i think my inverters some our although off are storing a small amount of current for a short while, because when I disconnected them the volt metre dropped straight away. I'm slightly confused as I think you may mean charger NOT inverter (the inverter provides 240vac). But whatever, both inverters and chargers will drop their output over a couple of seconds at switch-off. Chris Link to comment Share on other sites More sharing options...
colin loach Posted October 7, 2008 Author Report Share Posted October 7, 2008 Chris I have two inverters one 600 and the other 2000 watt both connected to the neutral buzz bar with all the other items, pumps etc. Link to comment Share on other sites More sharing options...
Guest TerryL Posted October 7, 2008 Report Share Posted October 7, 2008 He's not creating a problem, he's identified an existing problem which is real but normally hidden. The capacitor will preclude the problem ever becoming an issue. It's a safety thing. Chris Who asked you? If it should be connected permanently then it will create a problem same as disconnecting anything on the wrong side. Safety is not your thing is it? Link to comment Share on other sites More sharing options...
chris w Posted October 7, 2008 Report Share Posted October 7, 2008 Who asked you? If it should be connected permanently then it will create a problem same as disconnecting anything on the wrong side. Safety is not your thing is it? You don't know where you are in the world do you? On another post, you advocated not using an isolation transformer in case a lead broke and made it unsafe. Now you are saying that this guy doesn't need to protect against a lead's coming off? Make up your mind. I imagine this contrariness of advice of yours is why you were so unpopular that you were thrown off the other boating forum??? Link to comment Share on other sites More sharing options...
bottle Posted October 7, 2008 Report Share Posted October 7, 2008 Who asked you? SNIP>>>>>>>>>>>>>>>>>>>>>>>>>>> No one, this is a forum and we also have freespeech in this country. TerryL I realise that you have a problem with Chris w but may I ask you to desist from being aggressive it does you no favours and is getting a little tiresome. Link to comment Share on other sites More sharing options...
Keeping Up Posted October 7, 2008 Report Share Posted October 7, 2008 BTW, I mistakenly read Allan's original post as a suggestion of a 1000nF capacitor and did my calculations on that basis. In fact Allan suggested a 1000pF capacitor. IMHO, I feel a 1000pF will cause problems on MW as it will have too high an impedance (300 ohms). I believe (with all due respect to Allan) that a 1000nF would be a better choice. In fact anything in the range of 100nF to 1000nF should work fine. Chris Agreed; I used 1000pF because I never listen to Medium Wave Link to comment Share on other sites More sharing options...
Guest TerryL Posted October 7, 2008 Report Share Posted October 7, 2008 You don't know where you are in the world do you? On another post, you advocated not using an isolation transformer in case a lead broke and made it unsafe. Now you are saying that this guy doesn't need to protect against a lead's coming off? Make up your mind. I imagine this contrariness of advice of yours is why you were so unpopular that you were thrown off the other boating forum??? Wrong again. Link to comment Share on other sites More sharing options...
chris w Posted October 7, 2008 Report Share Posted October 7, 2008 Wrong again. What WAS the reason you were thrown off it then?? Link to comment Share on other sites More sharing options...
