sean white Posted June 2, 2005 Report Share Posted June 2, 2005 got a sterling 1800w inverter on boat never used it & got no manual. How does it work? Link to comment Share on other sites More sharing options...
buggsy Posted June 2, 2005 Report Share Posted June 2, 2005 Sean, look at sterlings website for the online manuals www.sterling-power.com i think this is the correct website. I have an 1800 watt modified sine wave on my boat everything works ok but avoid tv/video combis as ih ave yet to find one that works. cheers, Steve Link to comment Share on other sites More sharing options...
stuart Posted June 2, 2005 Report Share Posted June 2, 2005 got a sterling 1800w inverter on boat never used it & got no manual. How does it work? 21452[/snapback] Sean, do you use any mains electrical (230/240v) devices on your boat? You do know what the inverter does? Link to comment Share on other sites More sharing options...
DHutch Posted June 2, 2005 Report Share Posted June 2, 2005 got a sterling 1800w inverter on boat never used it & got no manual. How does it work? Its turns Your 12v DC into 240/230v AC Link to comment Share on other sites More sharing options...
John Orentas Posted June 2, 2005 Report Share Posted June 2, 2005 Sean. You can run 230 volt appliances off the unit up to 1800 watt power. Make sure it has been installed properly, remember the voltage output is every bit as dangerous as the electricity off the mains. The inverter will take very large amounts of power from your batteries, for prolonged use at high power arrange to run the engine whilst it is in use. Link to comment Share on other sites More sharing options...
DHutch Posted June 2, 2005 Report Share Posted June 2, 2005 The inverter will take very large amounts of power from your batteries, for prolonged use at high power arrange to run the engine whilst it is in use. And you want to place the inverter next to the batterys, and wire the two together with thick cable. To reduce voltage drop (inverters cut out on low voltage), and energy loss. Daniel Link to comment Share on other sites More sharing options...
sean white Posted June 3, 2005 Author Report Share Posted June 3, 2005 cheers all i'll have a look on sterlings website Link to comment Share on other sites More sharing options...
