fudd Posted April 12, 2008 Report Share Posted April 12, 2008 Hello everyone. If money was no object, what energy system would one install on a 70' live aboard replica dutch barge. Steve P. Link to comment Share on other sites More sharing options...
Windjammer Posted April 12, 2008 Report Share Posted April 12, 2008 If money were no object, I'd pay someone else to worry about it !!! Link to comment Share on other sites More sharing options...
fudd Posted April 12, 2008 Author Report Share Posted April 12, 2008 I see where you are coming from Windjammer, but I can probably afford the best and most efficient system but only if I fit it myself. I also like to know what I would be getting for my money. Thanks. Steve P. Link to comment Share on other sites More sharing options...
Gary Peacock Posted April 12, 2008 Report Share Posted April 12, 2008 Hello everyone. If money was no object, what energy system would one install on a 70' live aboard replica dutch barge. Steve P. Victron 5KVA Quatro Inverter Charger. Northern Lights 7KW cocooned genset. Victron VE Net to control those. 800 Ah of AGM batteries. Energy solutions ESP system for the DC side of things. Straight domestic style distribution for the AC side of things. Actually this is what we are fitting at the moment. It does become a bit complex though! Link to comment Share on other sites More sharing options...
fudd Posted April 12, 2008 Author Report Share Posted April 12, 2008 Victron 5KVA Quatro Inverter Charger.Northern Lights 7KW cocooned genset. Victron VE Net to control those. 800 Ah of AGM batteries. Energy solutions ESP system for the DC side of things. Straight domestic style distribution for the AC side of things. Actually this is what we are fitting at the moment. It does become a bit complex though! Thanks Gary. No mention of a dc generator then? Link to comment Share on other sites More sharing options...
chris w Posted April 12, 2008 Report Share Posted April 12, 2008 800 Ah of AGM batteries. Why AGM batteries Gary? In what way are they "best"????? Chris Link to comment Share on other sites More sharing options...
Gary Peacock Posted April 12, 2008 Report Share Posted April 12, 2008 Why AGM batteries Gary? In what way are they "best"????? Chris The owner can't do any maintenance he's in a wheelchair. We do normally go with AGM's though purely because we got fed up of having to try and claim under warranty for customers who neglected to top up wet cells or repatedly over discharged them. We also use Rolls Series 4/5000 which some say are among the best the price is a bit scary though but it does encourage a good maintenance schedule. People forget batteries are consumables and expect too much from them. The cycle life of AGM's and GEL are on paper better but if you abuse any battery the results will be the same regardless of spec and cost. Link to comment Share on other sites More sharing options...
chris w Posted April 12, 2008 Report Share Posted April 12, 2008 The cycle life of AGM's and GEL are on paper better but if you abuse any battery the results will be the same regardless of spec and cost. The cycle life of AGM's and Gels are NOT better than wet cells. You will never see a comparison in their specs against wet cells because they know the results are worse. They only show number of cycles of discharge against expected life................... and they use relatively shallow discharge figures in their graphs!! Chris Link to comment Share on other sites More sharing options...
Gary Peacock Posted April 12, 2008 Report Share Posted April 12, 2008 (edited) Thanks Gary. No mention of a dc generator then? Victron used to be great advocates of the DC concept but seem to over the last few years mentioned it less. On this boat it would be pretty pointless because the gen set will be run to power the air con (AC) for both cooling and reverse cycle heating most of this time. The gen set will have the excess power to charge the batteries via the quatro. Edited April 12, 2008 by Gary Peacock Link to comment Share on other sites More sharing options...
fudd Posted April 12, 2008 Author Report Share Posted April 12, 2008 Victron used to be great advocates of the DC concept but seem to over the last few years mentioned it less. On this boat it would be pretty pointless because the gen set will be run to power the air con (AC) for both cooling and reverse cycle heating most of this time. The gen set will have the excess power to charge the batteries via the quatro. Thanks Gary. I have read so much on dc gensets and they all state that they are much more efficient at charging a battery bank. Less hours = less fuel used, less hours on the main engine etc. Just don't know what way to go. Victron used to be great advocates of the DC concept but seem to over the last few years mentioned it less. On this boat it would be pretty pointless because the gen set will be run to power the air con (AC) for both cooling and reverse cycle heating most of this time. The gen set will have the excess power to charge the batteries via the quatro. Thanks Gary. I have read so much on dc gensets and they all state that they are much more efficient at charging a battery bank. Less hours = less fuel used, less hours on the main engine etc. Just don't know what way to go. The cycle life of AGM's and Gels are NOT better than wet cells. You will never see a comparison in their specs against wet cells because they know the results are worse. They only show number of cycles of discharge against expected life................... and they use relatively shallow discharge figures in their graphs!! Chris Cheers for your input Chris. What way would you go? You seem knowledgeable about these sort of things? Steve P. Link to comment Share on other sites More sharing options...
magnetman Posted April 12, 2008 Report Share Posted April 12, 2008 Just beware that boating is a very hazardous activity, you could DIE. It might be better not to take the risk. Link to comment Share on other sites More sharing options...
grahoom Posted April 12, 2008 Report Share Posted April 12, 2008 The cycle life of AGM's and Gels are NOT better than wet cells. You will never see a comparison in their specs against wet cells because they know the results are worse. They only show number of cycles of discharge against expected life................... and they use relatively shallow discharge figures in their graphs!! Chris i just read this in the sterling catologue page 17... Link to comment Share on other sites More sharing options...
