tosher Posted March 1, 2008 Report Share Posted March 1, 2008 Is there a simple way to power a 6volt appliance from the boats 12volt DC sockets? I have a digital TV aerial which has an internal booster. This booster is supplied with 6volt DC from a power inserter plugged into the aerial coax cable at the back of the freeview box. This power inserter is supplied from a 240volt AC plug with built in transformer/rectifier but unfortunately the nearedt 240 volt socket is some way from the TV which means trailing cables. Right next to the TV is a spare 12 volt DC socket so my question is ---- how can I supply the 6 volt DC power inserter from the adjacent 12 volt DC socket ?? The details on the power inserter say 6 volt DC 100ma but the actual measured voltage when plugged into 240 AC is 8 volt DC. Link to comment Share on other sites More sharing options...
PeterF Posted March 1, 2008 Report Share Posted March 1, 2008 If it is a low power item which I suspect it is you can get small power converters from Maplins that have a settable output voltage from something like 6V to 12V. I have used a couple of these on my boat and they appear to work well. One powers a 12V appliance that stated it would not want the 14.8V in the system during battery charging and the other 9V. The only problem is that they may have a low efficiency at low current draw. It is called a universal DC power supply and can be found on Universal DC power supply If you do not have a cigarette style socket then it is easy to cut the feed cable as long as you make sure you get the +ve the right way, it is the one which feeds the central tip of the plug. Link to comment Share on other sites More sharing options...
wonderdust Posted March 1, 2008 Report Share Posted March 1, 2008 Don't no if this would do the job? clicky Link to comment Share on other sites More sharing options...
ChrisPy Posted March 1, 2008 Report Share Posted March 1, 2008 can't you wire it up twice , in series with itself , so it gets half the voltage twice ?? ................................. er ... no. damn ! Link to comment Share on other sites More sharing options...
Yoda Posted March 1, 2008 Report Share Posted March 1, 2008 can't you wire it up twice , in series with itself , so it gets half the voltage twice ?? ................................. er ... no. damn ! What are you on?! Too much Turkish coffee? Link to comment Share on other sites More sharing options...
Keeping Up Posted March 1, 2008 Report Share Posted March 1, 2008 The Maplin power supply looks useful; I don't think I'd trust the VW Beetle thingy Link to comment Share on other sites More sharing options...
ChrisPy Posted March 1, 2008 Report Share Posted March 1, 2008 What are you on?! Too much Turkish coffee? No, I'm finished with Turkey, I'm looking forward to curries now Link to comment Share on other sites More sharing options...
chris w Posted March 1, 2008 Report Share Posted March 1, 2008 The details on the power inserter say 6 volt DC 100ma but the actual measured voltage when plugged into 240 AC is 8 volt DC. The Maplin type converter will do fine. The reason you're reading 8v DC, rather than 6v, is because you are measuring the converter off-load. Once on-load the current drawn will pull the voltage down to 6v. A well regulated converter would not do this but for cheapness many are not well regulated. Chris Link to comment Share on other sites More sharing options...
tosher Posted March 3, 2008 Author Report Share Posted March 3, 2008 Thanks for all your responses, I bought the Universal DC Power Supply from Maplins as suggested and it does the job nicely. Cheers -- tosher. Link to comment Share on other sites More sharing options...
