Tony Brooks Posted May 14, 2023 Report Share Posted May 14, 2023 1 minute ago, Tracy D'arth said: I close the lid. But it always wakes up on the keys, its after I have been using it for a while that it locks up. Everything else works but cannot type. Out of interest, have you tried the vacuum cleaner hose on all the cooing vents. It starts to sound as if it might be a heat thing. Link to comment Share on other sites More sharing options...
Tracy D'arth Posted May 14, 2023 Author Report Share Posted May 14, 2023 13 minutes ago, Tony Brooks said: Out of interest, have you tried the vacuum cleaner hose on all the cooing vents. It starts to sound as if it might be a heat thing. Very much doubt it is thermal, does it cold and this is a sealed fan less laptop. Acer Aspire V11 Link to comment Share on other sites More sharing options...
Guest Posted May 14, 2023 Report Share Posted May 14, 2023 (edited) 10 minutes ago, Tracy D'arth said: Very much doubt it is thermal, does it cold and this is a sealed fan less laptop. Acer Aspire V11 They still require ventilation, even if its not provided by a fan. They often vent through the keyboard or the heat is taken up by internal conduction meaning it dissipates via the internals meaning the case also needs to be kept cool to help it dissipate. Edited May 14, 2023 by M_JG Link to comment Share on other sites More sharing options...
robtheplod Posted May 14, 2023 Report Share Posted May 14, 2023 Instead of just closing the lid, go through the shutdown process - click on start, shutdown etc, then close the lid once its off..... I'm sure you have fewer problems doing this. The sleep feature of laptops is prone to all sorts of problems like this.... Link to comment Share on other sites More sharing options...
