Stopping boats elegantly by the canal side ?
Stroudwater1
11 minutes ago, cuthound said:
Mine was like that. When I had it docked I checked the prop size and pitch. Beta recommend 18" X 12" for the 43 with a 2:1 gearbox but mine was 17"x 11".
I changed the prop for the recommended size and it has transformed the boat. It now stops much better and cruises at a lower rpm which is quieter and uses less fuel.
Original spec sheet for our boat lists the prop as a 20 x 16 on a 2:1 box mated to the 43
Last survey identified the fitted prop as a 19 x 12
So either the specs are wrong, it’s worn down a bit, or it’s been changed at some point :)
