Battery operated nav lights?
tonyreptiles
6 minutes ago, LakinZ said:
I attached Attwood navigation light to the front rail of my pontoon boat. The starboard light quit and the wiring is bad, so I needed a quick fix for the fireworks display. A nice C-clamp makes these lights easy to mount and remove. I can even switch the lights between my canoe, rowboat, kayak, and Jon boat thanks to the handy C-clamp. No inconvenience occurs as batteries last for a decent amount of time.
What’s this total bollox? One of these computer replies?
Edited by PD1964
On 28/03/2021 at 21:32, ditchcrawler said:
Why not make a set up on a frame to sit on the roof with a lead plugged into a 12 volt socket
Why not buy emergency battery operated lights or some red and some green lightsticks. As others have said narrow boats are badly designed vis a vis  Colregs. I have proper nav lights port and std  but use them rarely, and in a tunnel I use a stern light to illuminate the rear steering area, the idea being to identify the  boat presence and type as best you can.
Worse case scenario  in case of a fatal accident inquiry your boat was visible in poor light or at night
Edited by LadyG
