timboharticus Posted March 19, 2005 Report Share Posted March 19, 2005 I have an old twin coil upright type which leaks a bit. Any ideas/experience. Araldite? Braze? Buy a new one you stingy b**? Link to comment Share on other sites More sharing options...
dor Posted March 19, 2005 Report Share Posted March 19, 2005 Where is it leaking? I recently had to replace a domestic HW tank which had pinhole leaks. Apparently since 2000 the standard has required thicker metal. Certainly with this one there was no alternative that to replace it. Maybe with yours the copper has just got a bit too thin. Link to comment Share on other sites More sharing options...
DHutch Posted March 19, 2005 Report Share Posted March 19, 2005 Yeah, we realy could do with know where about its leaking? Link to comment Share on other sites More sharing options...
ChrisPy Posted March 20, 2005 Report Share Posted March 20, 2005 Yeah, we realy could do with know where about its leaking? <{POST_SNAPBACK}> yeah, it would help ! Link to comment Share on other sites More sharing options...
timboharticus Posted March 21, 2005 Author Report Share Posted March 21, 2005 From the bottom LOL. There is a seam. Link to comment Share on other sites More sharing options...
ChrisPy Posted March 21, 2005 Report Share Posted March 21, 2005 (edited) From the bottom LOL. There is a seam. <{POST_SNAPBACK}> I would take it to a (car) radiator repair outfit, eg Serck Services. I had them make up a copper boiler for a model steam engine once. Edited March 21, 2005 by chris polley Link to comment Share on other sites More sharing options...
stuart Posted March 21, 2005 Report Share Posted March 21, 2005 If its a joint/seam in the tank itself then it may be time to replace it - if one seam has gone you can be sure the others are on the way out! Link to comment Share on other sites More sharing options...
nb maggie Posted March 21, 2005 Report Share Posted March 21, 2005 (edited) I would get shut pronto before it leaks worse and you end up with 20 gallons of water under your floor boards. My experience with (the older and thicker type) domestic tanks is that they don't repair very well. Edited March 21, 2005 by nb maggie Link to comment Share on other sites More sharing options...
DHutch Posted March 21, 2005 Report Share Posted March 21, 2005 yeah, if its seam, how old it the tank? it might be bad seam, in which case get is fixed, but as stu says, it might be time to think about an new tank. - or if your a bit short, get it soldered up and even if its old it will proberble last another season or two. Link to comment Share on other sites More sharing options...
nb maggie Posted March 21, 2005 Report Share Posted March 21, 2005 - or if your a bit short, get it soldered up and even if its old it will proberble last another season or two. <{POST_SNAPBACK}> The problem I have had with soldering is that the heat can weaken the whole seam, if its a soldered one. Link to comment Share on other sites More sharing options...
DHutch Posted March 21, 2005 Report Share Posted March 21, 2005 The problem I have had with soldering is that the heat can weaken the whole seam, if its a soldered one. Yeah, you have to use very low temp soilder. - when solidering a tank you usally make the first seam with high temp soilder, and the use progressivly low temp solder on the neighbouring seams, thus you dont melt the previous seam. Daniel Link to comment Share on other sites More sharing options...
ChrisPy Posted March 22, 2005 Report Share Posted March 22, 2005 The problem I have had with soldering is that the heat can weaken the whole seam, if its a soldered one. <{POST_SNAPBACK}> that's precisely why you should go to a specialist, as I suggested. they do it for a living. Link to comment Share on other sites More sharing options...
