pistnbroke
Contact Methods
  • Website URL
    http://
    up the cut
  • Occupation
    you guess
  • Boat Name
    Aspire
  • Boat Location
    UK
2,922 profile views
pistnbroke's Achievements
Collaborator
Collaborator (5/12)
3
  1. Most of the so called sealed batteries have a row of stoppers under the label..easily checked by rubbing your thumb over it or looking for the indentations ..if not then of course buy a drill.
  2. If you stop in rugby there is a 200 yard path from the canal bank to a Large Tesco..You will see all the shops from the elevated canal positon and the path is just after the next bridge.
  3. what part of if its treated it will be stamped as such dont you understand? This is so that customs in countries with real border controls ( ie australia) can check. They open and unload every container that goes into the country. Australians will not burn treated wood on open fires because of the toxins in the smoke.....
  4. If its got preservative in it it will have a burnt in stamp saying so ....That is so you can use it to send goods to say australia where they dont want wood bugs ....unstamped its OK
  5. If they cannot get it right on a Boeing 787 why do you think you can do it on a narrowboat..??
  6. but such thinking goes a long way to explaining why people find diagnosing electrical faults difficult. Excellent logic Tony I hate technocrap
  7. A wire from the B+ to the WL terminal will put all the alternator output via the field diodes and bugggger them ...you should have put a 5w bulb from B+ to WL to substitute a known good excitation circuit...Even if you burnt out the diodes it will still charge with the wire in place........
  8. First remember that you must test dont guess ( or it costs time and money) You must put a voltmeter across the battery and read the voltage when the fault exists. 12v or more would be good. Then check across the cables out of the batteries andwork your way towards the pump where you can get access. If the batteries are good and charged it is certain you have a bad connection which is reducing the voltage and causing the light problem. Ignore incorrect statements like the appliances are robbing each other of current ..never happened
  9. Personally Ive never seen a flat battery ..is that when its been run over by a truck? All mine stay brick shaped even when discharged
  10. If your main isolator switch was causing a drop of 1v then yes it will make a big difference. Ocasionally operate the switch as this will help keep the contacts clean. I think you are being told rubbish about your inverter ...microswitch ??? total load of bullshit....If your inverter is working /powering your loads fine ,not over heating or blowing its fusing then its fine.The only place power can disapear to is heat ..... Bet the person who told you this sells them . I suggest you dump the person who is your electrical advisor
  11. 140 A is only the maximum output into a resistive load. When charging a discharged battery you will get a max of 25 A per 100AH of capacity and that will fall very fast as the batteries come up. If it did charge at 140 A your batteries would get very hot as you have 3360 Watts available!!!
  12. The vent on that cell is probably blocked so the vapour etc has forced out via the built in hydrometer /eye
  13. batteries dont gas till over 14.4v.........and he said 14.4v
  14. Retirement on health grounds is the way to go ..get your pension now ..I retired at 45 ..bit like winning the lottery slowly....
  15. Fabreze is good just spray it on and that it
