Days Won
Everything posted by Derek R.
The caption states "The last coal run" but was it? Albert's two in Cassio, from D.D. Gladwin's 'An Illustrated History of British Waterways' published by Spur 1977 (P.145) shows a black and white shot taken from the top gates of "Cassiobury Top Lock 1970" with a gent in a beret steering the motor (and just beyond the bottom gates), and a lady in a headscarf and short 'shiny' jacket steering the butty 'Ara' - no writing on the cabin sides, loaded, cloths rolled up and a bike on the coal. Another question: Why 'Albert's two', and sometimes 'Mary's Two' (same pair of locks). We know about 'Sutton's', but who were Albert and Mary? Come to that - Peter below Maffas? Just local character/lock keepers, or is there a story? Derek
Cardboard? - Cheapskates! I'd thought of drilling a small hole in each end of the tube, and squirting expanding filler in. Wait for it to ooze out the other end, trim when set, fill, sand and paint. I agree the cross-heads need some movement to get the needles working, and for all I know there probably is some, but greased often enough, and the occasional disconnect for a waggle around should see them out live me. Not like they are under the stresses that a lorry would take. Derek
Only a few, but I've not seen them before. Most are of the Thames, but a few around Uxbridge and Brentford. The Swan and Bottle seems to have changed - a bit! http://www.ltmcollection.org/photos/themes...=1&IXpage=1 Derek
That Layrub coupling looks about as close to the metalastic that came out of Tycho than any of the others. I seem to remember it appeared like a solid rubber disc sandwiched between two metal plates. Quite how exactly it was fixed to the plates was not clear, no bolt heads could be seen, and tough as new motocross boots, but then it was seven years ago I last set eyes on it. Not only would it take some misalignment, it had a very good ability to transmit thrust ahead and astern. Also would take some of the shock when the blades hit hard objects - and It was mounted just as Tim states. Whilst we had no problems with our block deteriorating, we have heard of other types of flexible couplings involving flexible plates bolted at the lugs alternately to one plate then the other, failing catastrophically. The Layrub that Neil refers to looks more substantial, though the ability to efficiently transmit thrust might be in question, and I'll expand out of interest (hopefully - though not experience of the Layrub). It was the reverse/forward thrust issue that needed to be addressed when changing from our metalastic system to the lorry prop. The positioning of the plummer blocks mounted on the boats bottom in the previous setup meant that when on dock, the flexing that took place (bed'ole wouldn't close etc.) put stress on the shaft (depends where the stocks are of course). This in turn had worn the tailshaft and bearing prematurely - not that much flexing if any took place when afloat - but the shaft was not as well contained in its movement as would have been best for tail shaft alignment due to the distance from plummer block to tailshaft. The lorry shaft with its two UJ's is mounted between the reduction box output flange and the tailshaft flange and supported at the back by a new plummer block mounted on a cross web between the swim plates close to the tail shaft - and the reduction box output bearing at the front. This latter gave rise to showing up a problem that the previous set up had hidden: The old plummer block was fairly close to the reduction box output and had the effect of supporting the short reduction box output shaft and flange thereby keeping it more or less well aligned in the casing. The thrust bearing mounted in the output had worn, and now with the length of the new shaft weighing on it, showed its failing in an 'orrible clankety clank from under the floor in astern. It started this half way up the Stockton flight after leaving the dock. Sounded like the blades were hitting something. Thought it was a bit of ballast touching the shaft coupling bolt heads. None of the above! The drop in attitude of the reduction box output allowed due to the worn bearing, had tilted the larger pinion in the reduction box (3:1) and was allowing the cast web supports (four if I recall right) of the pinions face to contact one of the internal cast web supports of the reduction box casing. The sound was being amplified by the new hollow lorry shaft to frightening proportions. I soldiered on, and did a lot of strapping on that trip. I called Graeme, and he said there shouldn't be anything basically wrong with the set up, but to check that reduction box output bearing. Sure enough, it was at fault. One other point to bring up with such changes. The old reduction box bearing was a double ball race thrust bearing, the old plummer block bearing, I believe was not. The new tailshaft is now mounted in its stern tube bearing and a plummer block about eighteen inches forward of it. This bearing is now the thrust bearing, and the replacement that went into the reduction box output is a non-thrust bearing. Noise gone - problem solved. Or is it? The thought occurs to me, that such a length of steel in the form of prop shaft from rearmost plummer block to reduction box complete with two UJ's, that the expansion and contraction of the steel in the shaft, compared to the steel of the hull, will place 'some' load on that non-thrust bearing dependent upon tempaerature. The question is - how much, and will it have any detrimental effect? One solution to alleviate any such load through temperature change, might be to have the lorry prop machined and put a spline in place. The only problem with that (as I see it) is an additional introduction of a moving part prone to more wear and possible misalignment also. So it's staying as it is, with the aft most plummer block taking thrust. When not locked to the shaft, I can slide the tailshaft back and inch, and lift the lorry prop clear for access to ballast and bilge which was a lot harder with the old set up, and I know the tailshaft ain't moving out of alignment. Sorry this has drifted away from metalastic Tim, but it seemed to be associated knowledge and experience that might aid decisions for those in a similar situation (nearly said 'same boat'!). Derek
Building at the foot of Hurleston Junction?
Derek R. replied to Boatgypsy's topic in History & Heritage
I haven't been 'on the ground' thereabouts, but from the satellite pictures there looks to be what might have been foundations of a stable block close by the first lock and near the turnover bridge on the south side of the first lock. Also being a junction between two canals, some control over tolls to be collected might have needed a small building at least. Only a calculated guess I'm afraid. Derek -
So, do I win the Wooden Spoon award?
This crops up every year. We have a contributor from; Manchester; Bath; and the Peak Forest. If any of those folk have been personally disadvantaged in any way by such a run, perhaps their complaints can be directed to the alleged miscreants. Would any who are actually, or might be affected by the passing of a train of boats like to speak up? There will always be some. In '83 we were headed for Wigan and the IWA National. Our path was a slow three month cruise taking in the Peak Forest and Ashton canals. At the top of Marple we were hailed and vociferously complained to by a resident boater (we also lived afloat at that time) in that we were using water that they needed to keep afloat. 'Too many boats going to the National' was the cry. There are some I will not boat with, and whose practices I do not condone. This is not a moan about whingers, nor a voice for letting 'em rip as some might like to in recreating what they believe was standard practice years ago. But it does seem that whenever something from the past turns up in the garden, out come the guns - it's hunting season. Be it traction engines, old lorries, old buses, old motorbikes with speeds that 'hold up' the modern traffic - something that gives off a little smoke, picking Blackberries from a hedgerow "you know that's stealing" - if anything is certain, our 'nanny state' has taught us how to moan. There will be boats passing some at early hours and late. It's once every other year - so far - in which lock working efficiency comes to the fore. Genuine problems for others will, I am sure, be few and far between - that much is appreciated by the organisers, and by most who participate. I will not be, it's just not something that attracts me. Though if I were in the vicinity, I would gladly set a lock or three and help them through for the sake of remembering the crews that lived the life, and just a little of what was once the canal's reason for being. Derek
The same has been said about running light Locomotives over Network Rail's lines - cheaper on a lorry. I do not know the requirements that needed to be fulfilled at that time, but later in 1980, dole could only be collected after six weeks of unemployment, I neither know if Lesley Morton's comments were tongue in cheek to wind up certain factions, but it does sound like they might have been. The sums may have been done and possibly proven to be more 'economical', but the consequences for crews may not have been seriously considered - even considered at all - does anyone know? Ask Jackanory? Derek
Rose Whitlock, nee Ward, was born to Susan and Michael Ward in 1917 in a rented cottage by the locks at Rickmansworth. Her Father was away in France in charge of food supply barges, and her Mother had taken work at the boat docks at Rickmansworth for the duration. Upon returning, they went back on the boats. The full story of Rose Whitlock has been published in the Historic Narrow Boat Owners Club Newsletter from issue 2006/2 through to 2007/4 in seven parts, and 'narrated' by Tim Coghlan. Derek
Possibly coupled with the likelyhood that carrying on would leave them either outside the dock in 'no man's land', or inside and trapped. Uxbridge has facilities and entertainment close by, and a short morning trip would see them in the dock and available for unloading. I know when I drove delivery vans, if we finished the round early, we didn't rush back to the depot and get lumbered with 'odd jobs' to keep us busy, the caff was far more inviting! Derek
Late October. Contact Tom for exact dates.
I personally do not know the owners nor the price, but the second question may be countered by another - how long is a piece of string? A realistic price may be the most the vendor can get from the buyer - to the vendor. Conversely, the least that can be paid by the buyer. As with any market, a realistic price is one agreed to on both sides. What price? How long is a piece of . . . It's all relative to what you can afford, what value you place upon the item (an emotive aspect, unless you are a 'dealer'), and of course, what you intend to do with it. A realistic price may be one you can afford, and one which leaves you with enough left over to carry out the required plan. Then when all is done, and the item has reached the desired condition, it either gives immense satisfaction of a plan achieved, or it is sold on, and most likely realise perhaps less than half of that which has been spent on it completing the 'plan'. The most 'real' factor in the equation, is that at the end of the day, the buyer will be poorer of pocket though hopefully wiser, and possibly without in this case a boat, or - enjoying a euphoric state of mind that exists in dreamers (albeit with the cost of ongoing maintenance and other associated fees). Long live dreamers. It's just a pity that money gets in the way of the fulfilment for most. Then again, one persons dream may be another persons nightmare, which brings us back to looking at that last picture of what was 'Spitfire'. Derek PS Most peoples material dreams when fulfilled are enjoyed by spiders in the main. Mine have been.
This is your man Casper:
Well, as you like chocolate, and it looks like a floating Toblerone . . . Don't be taken in by the "25% discount on licence fees". In his dreams - it's 10%, and proof of a percentage of the boat has to be shown. In which case this one could be debatable. I've got a chicken run that shape. Derek PS Looking at the inside, I'm reminded of an aircraft with a line of paratroopers waiting to drop over Arnhem. The bottom fell out of that one too.
I've a great deal of respect for corrugated iron, but getting back to Spitfire - it's as though someone has grafted the bottom part of a Reliant Robin onto an Aston Martin. I'm sure the owners believe they are doing the best they can with whatever finances are available, but that does not show much respect for either a bit of industrial history or the reason for its original shape. One can either take the view that it has been 'butchered', or saved from a worse fate: sunk; sectioned and scrapped. Derek
I think we are all a bit speechless about that sight.
As a life long motorcyclist - 45yrs+ - twenty eight of which was spent despatch riding, I have a different outlook to motorcycling than most who ride to work or for pleasure at the weekends. It formed a way of life that riding for fun never did. Yet at no time did I consider myself aloof, or better than any others except perhaps in the case of experience - and I was always willing and ready to impart any that I thought might help a lesser experienced person especially when asked. I am not the easiest person to approach and chat with, but strike the right chord and I don't stop. However, this exchange is becoming like cats spitting, and without noticing, those spitting loudest have not seen the sodding great Rotweiller coming round the corner with H.M. on its collar. With impending financial cuts, Waterways are going to be 'up against it', much like motorcycling is currently. We are going to need all the collective support there is if our chosen lifestyles are to survive in the face of legislative and financial problems ahead. Derek
Large old Radios in working boat cabins.
Derek R. replied to alan_fincher's topic in History & Heritage
It is an interesting subject, and I have yet to spy one just like that shown in Banstead. Perhaps Richard might recognise it at Past Times Radio: http://www.pasttimesradio.co.uk/index.html I think as Alan implies, many would have jumped on the 'new' transistor radios of the sixties. Prior to that, maybe 'word of mouth' was more reliable than batteries!! Derek -
Priceless in the eyes of those in love. My little FMC booklet lists Clent as being built in December 1947, Clee as July 1947. Though there is Cotswold listed but without a date beside it, just a -. Numbered 355 and the comment scrapped, and shows no registration number. Perhaps it never got off the dock complete. Derek
And I thought spiders was off topic! Seem to be in the right place after all . . .
Compared to the other shot, there's a few ton of something in there. Derek
Aah! But if it was growing from your window frames? That grass is being fed by decomposing timber as well as dust and accumulated wind blown dirt. Still, nothing that cannot be sorted out, but it does need sorting out before another season passes. Derek
Spiders never fail to amaze me at their ability to bridge almost impossible places! It (they) must have planted one end on the staging, took a look around, decided on a second point of anchorage, then worked out the direction in which to proceed to reach it without the silk getting stuck or hung up anywhere in between. Absolutely amazing. Is this off topic? Where am I?
Aldgate:
Legs: All depends how much room you have and whereabouts you want the top plate to be level with in relation to the back step etc., and aesthetics. That one was without legs and fitted to a couple of bits of angle screwed to the shelf. If you can get away with it, cut down legs can give some room for sundry cooking or cleaning items to slide under the stove, but you don't want it sitting on a pair of legs that poke it up too high - so cutting the legs to the required is sometimes undertaken. Level with or an inch or two above step level seems about right. A visual appraisal is best. But you do need some air space beneath - and mounted on fireproof material. I was trying to get another picture up, but Photobucket are messing me about with resize rejections just now now matter how small I make them. Good mind to drop them for something else. Derek
