East West use 2 types of wood Bamboo and Oak I am pretty sure that the wood on the floor,sides and ceiling is Oak not bamboo. The dinnette table and doors/drawers and most fittings are bamboo although is is very hard wearing I personally would not use it on the floor. Saw your link -- it looks really good
YES I HAVE A CHINESE BOAT. I have been using it on a regular basis for 6 years and I must admit it let me down ONCE the gear change cable snapped. If it was possible to get a bigger one now ( they stopped trading/building 4ish years ago) I would buy another without hesitation.
Thank you all so very much. 1 last point please. By placing the shunt in the battery cable does this have any effect on the charge or output of battery power ? and could I take the power to the ammeter (to work it not the shunt) from the accesory side of the key switch so that when I turn the ignition off the ammeter is turned off. Thanks again
3 1/2 Blue LCD Digital AMP Panel Meter AC 50A + ShuntThis is the link http://www.ebay.co.uk/itm/390221397131?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
Thanks Julynian for you help
Hi boaters
Need a bit of help please. I have 2 alternators on my boat each with a charging (ignition) lamp to show "charging. I am in the process of fitting an updated control panel and I have seen some digital ampmeters on ebay able to handel the current output from each alternator. The gauges have 4 connections 1) battery +ve 2) battery - ve (that bit is easy) but 3 and 4 I have no idea. I presume 1 will go to the alternator and the other to the earth side. Anyone please know where etc.
thank folks Ivor
This type of engine has NO pre heats. On mine there is a facility to "warm " the engine by starting the heater (Espasher ?) and the hot water circulates around the engine thus "warming" it. Sorry for the crap spelling but I am on the move and trying to type at the same time. If you want a more indepth explanation leave a note and I will add more when I stop later.
I am sorry to have caused this big discussion I dont want to "go all out" for using marine band and obtaining a licence after taking exams and all that stuff I just wanted to know if someone up the canal had any problems with kids throwing stones, a big fishing match or the lock was out of order. If I was a lorry driver and I needed help I could use band 19 ( I think that is the channel) to get help or warn other drivers of impending dangers. Sorry to have "opened" old wounds but it was a thought I had.
Thanks for that Ally I have tuned into this when travelling up the Macc. but I was thinking of a system like the lorry drivers use. If I met an obstruction I could "call it in" to forewarn others behind me if you "see" my drift.
Hi All
I have been using an air scanner (bit sad I know but. it passes the time)and like listening to aircraft as well as some of the "public" bands as well as the ham radio guys. I have a narrowboat and was wondering is there a channel the Canal boats use (probably on a CB band) I dont mean the dedicated marine band for weather and sea going vessels I mean a band for narrowboats for instance if I was travelling the Trent and Mersey through Stoke etc I could "tune into ???? and see any problems stoppages etc."
I have never heard of like this but someone out there might have. PLEASE only serious answers
Thanks
