Everything posted by MartinW
Haha, although the best pies are undisputedly made in Cleckheaton there is no 'us and them' in the pie-loving world, just sheer enjoyment.
Whose pies are they? (Pork-pie-lover joke)
That's a good couple of hours or more depending on bridge opening skills but is a realistic target for a first afternoon. The canal planner app is an excellent guide.
Sealing heating pipes through narrowboat engine bay bulkead
MartinW replied to Telstar's topic in Boat Building & Maintenance
Just an idle thought, but shouldn't the circs be in 22mm? Also if you lift the pipes up higher that might make a potential airlock? -
You will be able to get to the top of 5-rise at a pinch providing all the bridges are ok - there are lots! - On the electric ones remember to keep the closing button pressed until the whole cycle is complete. Recently you have had to book passage through 5-rise in advance but that might be different now. If you moor up at 5-rise after the cafe closes, walk down into Bingley for lots of Aldi/Lidl/Home Bargains shopping and some good food places. When you moor-up the day after in Saltaire and explore the mill, walk up Victoria Road for some interesting bakeries and the splendid Chapel. There is a real-ale bar called 'Fanny's' at the top, by a chip shop so you can get the full-fat immersive experience. Saltaire main street has some good coffee-shops a great wine-supplier and butcher (where the constant queues are a testament) Back on the other side of the canal is a fairly good bar/restaurant and a little further afield the lovingly tended Glen Tramway which is a splendid relic taking you up to Shipley Glen, where mill-families would travel for a cup of tea and a bun on high days and holidays. The Glen pub has a locally famous quiz-night where cheating is compulsory (it must be because my brother once won it) Further-on the canal there are a couple of good pubs like the Stansfield Arms at Apperley Bridge and then I run out of knowledge or talent or experience so you are on your own. After all, the journey is the goal, not the destination. Have a great time but don't try to plan too much in advance, as Erwin Rommel had written on his wall - 'No plan survives first contact with the enemy' Cheers!
I'm guilty of kidnapping this post so I'm sorry but just to let everyone who was kind enough to help know, I have 55litre twin-loop Surecal but it has neither accumulator on the cold feed or expansion bottle. It does have a PRV as standard. The system was obviously put in at a bare minimum specification so I will probably have to set-to and do it right. Thank you for your forbearance and apologies to Clan1 for the rudeness.
Thanks Jen. Yes I cleaned the inlet filter. I'll investigate the rest after I investigate a leaking sink waste. Cheers
I am gradually recommissioning ( a posh word for replacing everything) my long-neglected boat and got around to filling up the water-tank and opening the main stop tap. The Jabsco 2.9 operated as advertised but was very noisy. After two days of congratulating myself on my hose-pipe and tap-turning abilities the pump stated to run on after taps were closed. I have no accumulator fitted, just a calorifier, so I assumed I had a tired pressure switch. I fitted a square D from RS on a Tee in the pump output pipe and wired it in. As I did that, I realised that the pump and pipes were touching the tank at one side and the bulkhead at the other which explained the noise. The pump runs much quieter but still doesn't shut off when the taps are closed. I adjusted the screws on the switch but cannot stop the pump. I will have a look at the calorifier today and see if I can see the Schrader-valve to check what's happening there. I did notice that warm water was coming out of the cold tap in the galley but thought that that might simply be because the two pipes run next to each other. I guess that you are now about to tell me that my cauliflower is cooked....
Electrical issues - please point me in the right direction.
MartinW replied to MartinW's topic in Boat Building & Maintenance
Sadly, I think I can see the flats of the nut holding it in. Something else to add to my list of 'best practice' to implement as and when funds and opportunity allows. Thanks all. -
Well for that reason I shall dismiss the foolish thought from my head. There is room for a shut-off . Thanks, Tony. I took your advice on fitting small fans behind the fridge. Once I got the fridge out I could see that the housing unit was very badly marked and blistered so there had been appreciable heat at play at some time. The Beko fridge was subject to a recall, which it seems mine has had, so I think that the previous owner had a lucky escape. -
In balmy spring sunshine today I replaced the bilge pump and linked the flow and return for the now defunct Mikuni together .so I can still use the engine or Immersion to heat water until I decide what to replace it with. I fatally removed one loose tile from the shower wall and ended up pulling off the rest (mostly with my fingers). They were tiled onto OSB board which had been treated but still wasn't very good at hanging on to the tiles. Now I have that board out I can get to the space between the shower tray and the hull to check for rot (amazingly, it was fine). The shower tray is connected to the Gulper by flexible pipe. I should dearly like to connect the basin into the shower drain system as it's current skin fitting is too near the water for peace of mind (!00mm) I wonder if anyone does a multi-inlet box WITHOUT a pump in it so that I could connect shower, basin and gulper into it? I could place it by the Gulper (Under the bed) so it could be serviceable. -
And Ed Biers has impressively just replied to confirm that parts are unavailable and that an MX60 would be too big so I'll be looking for another solution.
I knew that there must be a good reason for what felt like an over-simplification. Thank you.
ENGINE OIL - Where can I dispose of used engine oil safely???
MartinW replied to James H's topic in Living Afloat
I think that if anyone were really serious about a green recovery they would mandate a national policy on recycling, from colour of bins to access to disposal centres. Most of the restrictions are a result of the individual contracts by local councils with Biffa et al, leading as was stated earlier, to the need to stop the 'Rubbish Reivers' popping over the border. I live in Kirklees but the nearest tips are in Bradford and Calderdale Authority. I have to travel further (Nearly into the Leeds Authority) to be told which items are no longer accepted, ceramics, rubble and old oil, for example. I was given Covid restrictions as the reason old oil was no longer accepted and ceramics and rubble because too many people were leaving them. This is on a site with number recognition and a need for a pass and a ban on trailers over a certain size. It has always confused me how the customer is dictated-to by the provider. each of the local authorities has a different number of and colour of bins, in some cases the opposite to each other. The viability of recycling of a type of plastic, for example, depends very much on the distance that the waste has to travel to be recycled. The answer surely has to be to build more recycling mills and work together rather than in splendid isolation. Rant over, but I know that people with more recycling industry experience than I inhabit this forum and so will soon tell my why I am mistaken. -
Apologies if I have started an unnecessary new post but I did look in the search results first. My non-functioning Mikuni MX40 was sent to Mellors for checking and they say that the air motor has gone and that parts are no longer available. MV confirm a lack of stock. I have contacted Ed Biers at four counties to see if he has any known good ones ad await his suggestions but most people seem to be offering a complete replacement (Webasto or MX60) configured to make installation as straightforward as possible. The (twin-coil calorifier) system as installed is very simple with just an on/off switch and no apparent thermostat except perhaps the overheat cut-out and no trvs on radiators. I expected to find a proportioning valve to split water and heating but I think that that s because I am used to domestic systems. Has the hive-mind any suggestions as to the most sensible way forward, and if TRV's (except the towel rail ) are a good idea whilst I have it drained down please?
C&RT say don't empty your compost toilet in our bins.
MartinW replied to Alan de Enfield's topic in General Boating
I have spoken with a small manufacturer of dry-solid toilets who supplies a specifically designed, marked and coloured bag for disposal. She also sells toilets to that larger world across the towpath who have camper-vans and other similar activities. I wonder if our smart forum-contributors might think outside the barge and look at more national system which would make the economics more approachable. I don't actually think most buyers actually think that they have to compost themselves, but that it magically happens inside the device, despite most suppliers specifically saying how it works in reality. and that is key to making a system work rather tan banning it out of existence. I remember when they banned turbos in Group ................. -
update for today, Thursday. I fired up the generator and it ran for four hours with the charger on 'High' 'Recondition' mode. (Like the instructions say, It flashed for an hour and then changes mode. Through all that time the generator was working hard. At that point rain stopped play at about the same time I ran out of petrol, so I'll refill my can and repeat the process, hopefully on Saturday. I took the opportunity to try out most of the 12volt circuits. most worked except the radio which runs off a four-fuse block so I pulled the fuse to find it and it's contacts white with fuzz and in need of replacement, which I will also do. The new bilge-pump uses 28mm ID hose so I've ordered some of that and a reducer to the original 20mm which I will place as close to the skin outlet as possible to keep flow restriction to a minimum. Will this discovery of disasters ever end? probably not, but at least I'm not under any illusions about that. -
haha Made my day. You might think so, I couldn't possibly comment. -
I was speaking as an oft comed'un (Yorkshire version of outlier) based on observing 7 or 8 pages of discussion. My boat has a Thetford but I was considering the dry-solids alternative, not because of any squeamishness on my part but rather the enhanced flexibility of disposal. I had no idea that there was so much controversy about that process. I have some experience of the problems caused to customers by poorly negotiated local authority waste-disposal contracts and also as a Park-conservation volunteer, the issue of dog-waste. If this pandemic has taught me anything it is that the constant pursuit of confrontation in support of a polarised viewpoint is a form of mutually assured destruction. The only people that benefit are those who seek to profit from division and the victims are kindness and mutual respect. I am, like you a proponent of the cock-up theory of just about everything. -
After a weekend's worth of comments I wonder if C&RT have actually stated this is a new policy and that Damien (working from home) had perhaps unwittingly broken an embargo on that change of policy before its actual announcement? It might also be a bit of kite-flying to gauge response which is probably presupposing an unprecedented (isn't everything) level of sophistication but certainly demonstrated how divided and easily conquered the contributors to this discussion here were. -
On the home page this post-headline reads as if the Happy Nomad rescued the girls himself! Made me chuckle.
I also found a surecal instruction leaflet online that helps explain the various connections in a twin loop calorifier so I can start labelling-up next vist. -
Oh, that explains that, thanks, Brian -
yes, it was upside down! Doh! Two of the four pipes heading backwards are the radiator flow and return and the other (Top) two are to and from the mikuni. This picture shows the pipes going forward from the calorifier to the heating, kitchen hot (along the wall), shower hot (on its own). There is a drain-off as well which I think is the one resting on the ballast brick! This might make it clearer
