Gender
Location
Cleckheaton
Occupation
various
Boat Name
Thor's Hammer
Boat Location
Leeds/Liverpool
MartinW's Achievements
Contributor (4/12)
19
MartinW changed their profile photo
Haha, although the best pies are undisputedly made in Cleckheaton there is no 'us and them' in the pie-loving world, just sheer enjoyment.
Whose pies are they? (Pork-pie-lover joke)
That's a good couple of hours or more depending on bridge opening skills but is a realistic target for a first afternoon. The canal planner app is an excellent guide.
Sealing heating pipes through narrowboat engine bay bulkead
MartinW replied to Telstar's topic in Boat Building & Maintenance
Just an idle thought, but shouldn't the circs be in 22mm? Also if you lift the pipes up higher that might make a potential airlock? -
You will be able to get to the top of 5-rise at a pinch providing all the bridges are ok - there are lots! - On the electric ones remember to keep the closing button pressed until the whole cycle is complete. Recently you have had to book passage through 5-rise in advance but that might be different now. If you moor up at 5-rise after the cafe closes, walk down into Bingley for lots of Aldi/Lidl/Home Bargains shopping and some good food places. When you moor-up the day after in Saltaire and explore the mill, walk up Victoria Road for some interesting bakeries and the splendid Chapel. There is a real-ale bar called 'Fanny's' at the top, by a chip shop so you can get the full-fat immersive experience. Saltaire main street has some good coffee-shops a great wine-supplier and butcher (where the constant queues are a testament) Back on the other side of the canal is a fairly good bar/restaurant and a little further afield the lovingly tended Glen Tramway which is a splendid relic taking you up to Shipley Glen, where mill-families would travel for a cup of tea and a bun on high days and holidays. The Glen pub has a locally famous quiz-night where cheating is compulsory (it must be because my brother once won it) Further-on the canal there are a couple of good pubs like the Stansfield Arms at Apperley Bridge and then I run out of knowledge or talent or experience so you are on your own. After all, the journey is the goal, not the destination. Have a great time but don't try to plan too much in advance, as Erwin Rommel had written on his wall - 'No plan survives first contact with the enemy' Cheers!
I'm guilty of kidnapping this post so I'm sorry but just to let everyone who was kind enough to help know, I have 55litre twin-loop Surecal but it has neither accumulator on the cold feed or expansion bottle. It does have a PRV as standard. The system was obviously put in at a bare minimum specification so I will probably have to set-to and do it right. Thank you for your forbearance and apologies to Clan1 for the rudeness.
Thanks Jen. Yes I cleaned the inlet filter. I'll investigate the rest after I investigate a leaking sink waste. Cheers
I am gradually recommissioning ( a posh word for replacing everything) my long-neglected boat and got around to filling up the water-tank and opening the main stop tap. The Jabsco 2.9 operated as advertised but was very noisy. After two days of congratulating myself on my hose-pipe and tap-turning abilities the pump stated to run on after taps were closed. I have no accumulator fitted, just a calorifier, so I assumed I had a tired pressure switch. I fitted a square D from RS on a Tee in the pump output pipe and wired it in. As I did that, I realised that the pump and pipes were touching the tank at one side and the bulkhead at the other which explained the noise. The pump runs much quieter but still doesn't shut off when the taps are closed. I adjusted the screws on the switch but cannot stop the pump. I will have a look at the calorifier today and see if I can see the Schrader-valve to check what's happening there. I did notice that warm water was coming out of the cold tap in the galley but thought that that might simply be because the two pipes run next to each other. I guess that you are now about to tell me that my cauliflower is cooked....
Electrical issues - please point me in the right direction.
MartinW replied to MartinW's topic in Boat Building & Maintenance
Sadly, I think I can see the flats of the nut holding it in. Something else to add to my list of 'best practice' to implement as and when funds and opportunity allows. Thanks all. -
Well for that reason I shall dismiss the foolish thought from my head. There is room for a shut-off . Thanks, Tony. I took your advice on fitting small fans behind the fridge. Once I got the fridge out I could see that the housing unit was very badly marked and blistered so there had been appreciable heat at play at some time. The Beko fridge was subject to a recall, which it seems mine has had, so I think that the previous owner had a lucky escape. -
In balmy spring sunshine today I replaced the bilge pump and linked the flow and return for the now defunct Mikuni together .so I can still use the engine or Immersion to heat water until I decide what to replace it with. I fatally removed one loose tile from the shower wall and ended up pulling off the rest (mostly with my fingers). They were tiled onto OSB board which had been treated but still wasn't very good at hanging on to the tiles. Now I have that board out I can get to the space between the shower tray and the hull to check for rot (amazingly, it was fine). The shower tray is connected to the Gulper by flexible pipe. I should dearly like to connect the basin into the shower drain system as it's current skin fitting is too near the water for peace of mind (!00mm) I wonder if anyone does a multi-inlet box WITHOUT a pump in it so that I could connect shower, basin and gulper into it? I could place it by the Gulper (Under the bed) so it could be serviceable. -
And Ed Biers has impressively just replied to confirm that parts are unavailable and that an MX60 would be too big so I'll be looking for another solution.
I knew that there must be a good reason for what felt like an over-simplification. Thank you.
ENGINE OIL - Where can I dispose of used engine oil safely???
MartinW replied to James H's topic in Living Afloat
I think that if anyone were really serious about a green recovery they would mandate a national policy on recycling, from colour of bins to access to disposal centres. Most of the restrictions are a result of the individual contracts by local councils with Biffa et al, leading as was stated earlier, to the need to stop the 'Rubbish Reivers' popping over the border. I live in Kirklees but the nearest tips are in Bradford and Calderdale Authority. I have to travel further (Nearly into the Leeds Authority) to be told which items are no longer accepted, ceramics, rubble and old oil, for example. I was given Covid restrictions as the reason old oil was no longer accepted and ceramics and rubble because too many people were leaving them. This is on a site with number recognition and a need for a pass and a ban on trailers over a certain size. It has always confused me how the customer is dictated-to by the provider. each of the local authorities has a different number of and colour of bins, in some cases the opposite to each other. The viability of recycling of a type of plastic, for example, depends very much on the distance that the waste has to travel to be recycled. The answer surely has to be to build more recycling mills and work together rather than in splendid isolation. Rant over, but I know that people with more recycling industry experience than I inhabit this forum and so will soon tell my why I am mistaken.
