tosher
Everything posted by tosher
  1. I had some trouble with my Vetus 55kg BT after 5 years use, speed was very erratic in one direction. The problem was a bad contact on the brush leads under the securing screw. These units are quite robust but are likely to misbehave sometimes. It is a DIY job to remove the motor, remove and clean the brushes, clean the comm, strip down the contactor and clean the contacts then replace. A good fettle up like this will usually solve most problems and it really is not difficult.
  2. Just a thought, from the OP's description of what happened it would appear quite possible that only one wire (or maybe two wires) were faulty that caused the engine to start. All other electrical systems seemed to be behaving normally at the time. So is it correct to blame the whole wiring loom for the fire when only a couple a wire were responsible.????
  3. My bet would be condensation, especially if the engine is run in these sub zero temperatures. If it is a leak then the source must be identified.
  4. I have had a Numax engine start battery for 6 years now and it's still going strong but my engine alway's starts first turn of the key so the battery has never done any serious cranking. Not onboard at the moment so can't give full details, I can only remember it says "Numax Heavy Duty" on it. (Hope I'm not tempting fate with this post)
  5. I must lucky too, now into my 6th year with my Elecsols and still going strong dispite abusing them badly for the first 2 years through lack of propper monitoring/charging.
  6. Thanks for that "collontheavon" it sounds like it is exactly what I wanted to know. I will try it on an old one I have at home and see if it works for me, will keep you posted, Thanks again - tosher.
  8. Watching this thread with interest as I tried and failed to change mine for exactly the same reason. Ended up just changing the "O" ring even though there was some wear on the nylon bush.
  9. I think it is essential to use some form of change over arrangement. I used a switch like the one mentioned above, double pole and 4 positions, OFF-1-2-3. I use positions 1 or 2 for shore power and 3 for inverter output. Got it from Puffer Parts for about £25ish and works a treat.
  10. These de-sulphaters were discussed on the forum quite some time ago and I seem to remember some knowledgable person posting saying that the more expensive Sterling multistep chargers have this facility built in. Anyone remember that?
  11. Same problem here, tried Internet explorer, Mozzila and 3 dongle but all the same. Fine now.
  12. tosher
    apologies
    You only have to take a boat through a few of locks to relise that it is/would be far more awkward if another boat was tied up on the lock moorings. For some one to own a boat for 12/18 months, even if it's not moved very far, and not realise that is a bit beyond me I'm afraid.
  13. Don't think you could have illustrated "Doormans" point in an earlier thread any better!! Good luck with the launch aharg and enjoy your time afloat.
  14. Of course any marina owner should be allowed to put down any type of road surface they see fit and impose any speed limits they think appropriate, I have no problem with that. I meerely expressed my surprise at the 5 Star rating. I would expect any business that invites public access, whether it be a hotel, camp site or marina etc and has a top 5 Star rating to be accessed by a reasonably smooth tarmac roadway, and not "resemble a farm track" as you accurately describe it. Perhaps the priviso you mentioned was aimed at the appearance of the roadway,the hedges, fencing and grass borders etc rather than at the actual raod surface itself.
  15. Couldn't move the boat my bow thruster doesn't work !
  16. A bit surprised by this award considering the state of the pot hole riddled approach road. Many of the berth do not have a water tap dspite what the advertising blerb says - Not 5 star rating in my book. Think I agree with the previous posts on this one.
  18. I have this arrangement with an extractor fan sucking the air out. It works well and does not affect the engine breathing at all. It also keeps the engine bay a bit cooler and cleaner. tosher
  19. Advice please-----I often leave the boat unoccupied for a couple of weeks at a time and always leave the shore power lead disconnect(galvanic corrosion etc etc). I would like to leave an oil filled radiator switched on to protect against frost. I thought about using an extension lead to connect the heater straight into the leccy post on the pontoon to avoid having to "plug the boat in". Is this in any way harmfull as there would be no one onboard when the heater is connected. The leccy post does have two circuit breakrs on it, one is overcurrent and one is earth leakage(I think). I have a feeling this is not best practice. tosher.
  20. Passed him 3 weeks ago in Brewood in exactly the same condition. Must be a valuable cargo???
  21. Interesting, that's just what I was told by Crowthers some years ago. Anybody any idea what this measurement should ideally be ?? tosher.
  22. Same here, didn't know they were goung up, thanks for that I've just ordered some. tosher.
  23. Ditto.
  24. Are your batteries "Elecsol" - these have a lower sg than normal open lead acid types.
  25. Thanks, will try it sparingly. tosher.
