As I mentioned in one of my early posts before Christmas, the temperature of liquid fresh water at atmospheric pressure cannot be significantly lower than zero Celsius. This means that if your engine space is not insulated below the water line it is highly unlikely to freeze unless there is lots of ice on the cut. In Theodora I am likely to be losing a lot of heat through the rather badly fitting board covering the engine space. Losing it to the air, that is. The air, of course, can be as cold as you like. This lost heat will mean that there has to be heat flowing into the engine space from the surrounding cut and will be conducting through the steel hull.
All this theory did not stop me getting panicked last night and driving 35mins at 2100 to check that the old girl is OK. She was, and when I measured the temperature I found that even the air temperature was only just on zero. I have left a max/min thermometer in the engine space just to check.
Theodora is a little more difficult to protect than more modern boats. She has a raw water cooling system and the only way that I have discovered to protect that is to open up the mud box, poor in a pint or two of antifreeze and then run the engine to pump it through the system. The difficult thing is to know how long to run the engine. Tomorrow when we go down to start really working on her I will take some fluorescein powder, mix up a strong solution and time how long it takes for the colour to appear in the water coming from the exhaust pipe.
Nick
