rgriffiths
Gender
2,679 profile views
rgriffiths's Achievements
Collaborator (5/12)
11
rgriffiths started following BMC 1.5: occasional misfire, some smoke, running fast on idle , Perkins MC42 - Drain tap replacement , Engine noise and 1 other
I have a leaky drain plug issue, the same as this problem here: https://www.canalworld.net/forums/index.php?/topic/44259-perkins-mc42-water-drain-tap/ Mine has sheared off when I tried to remove it. I have chipped away at the old one and the centre of it has come away easily, but it has left the outer threaded part still in the block, very difficult shift. I have tried various tools such as a scribe to pick at the metal but not really getting anywhere. Any tips, or is it just a case of more chipping away? I have considered getting a tap but I am not sure of the thread size. Any thoughts? Perkins replacement part number: 198736120 DRAIN TAP
Yes, inspected the rocker arms and all look fine. It certainly sounds like it is coming from this area. The head was taken off and fully checked over by specialists (pressure test, valves etc) but it's possible they may have missed something with the rocker arms. Will do some more investigation along with Alan's long screwdriver stethoscope idea. I have stood on it and no change.
Thanks all. Yes - that's the one. Tick, tick, tick, tick..... Definitely sounds like it is top end, and is not a mount. When I got the injectors checked, I was told there was signs of water in one of them. They said I might need to get the pump checked. Could water in a fuel pump make such a noise?
I have a Beta marine engine 1998, the Kabota 1505 type. Runs fine but I have this tapping/knocking noise that I can't diagnose. http://sndup.net/d2tb I have had the head off, injectors checked, tappets set to 0.010 inch. All fine. I can hear the tap as the engine turns over too, before it fires up. Before I go down the route of pulling the whole thing out and stripping, or possibly replacing it., I wondered if anyone here might have some bright ideas.
For anyone interested this is what happened : Got it out, welded up and good as new I hope. Found the drive plate was broken too so changed it at the same time. Thanks for all the help and advice.
That's kind of you. We are in London though. Just out of interest does anyone know what the material is most likely to be? It looks like aluminium but might it be cast iron?
Thanks all. Sadly the one on ebay is not the same and I am not sure will fit. I will have a trawl around to see if I can find one. Failing that I think a weld plus extra strengthening as you suggest Tony.
Again thanks. I was about to ask the same question ... where from? While I suspect it must be, does it have to be like for like or are there alternatives that might work? I can't seem to find anything on the net that looks like it.
Thanks for the advice. I was wondering if that was the only way. I suspect it has been broken for a while and can only speculate why it broke. I was thinking whether it would be better to try and get a replacement bellhousing?
Just a quick update, along with thanks for all the tips. It turned out that a combination of putting in a thermostat (I didn't realise it was missing), a glowplug not fully tightened, a couple bolts holding down the throtle cable in place loose causing the high revs on idle. etc etc. All these little things sorted and the engine runs much better with no misfiring. So a bit of a false alarm but all advice above very useful for the future - thank you.
I have a BMC 1.5 that has always been very reliable. However a few months ago it started to occasionally misfire on idle and with each misfire a small puff of smoke (more white than any other colour) was seen at the exhaust. All fine under load. All filters are new and oil changed etc. Next I took out the injectors to be checked. They were in poor shape had them all reconditioned. The engine continues to run fine under load but still get an occasional misfire on idle (every 2 or 3 seconds, but not regular) and the smoke now is definitely bluer. The other change is that it is running much faster now in idle than it did before the injectors were reconditioned. A local diesel injector company have suggested that I do two things: 1 - remove the top from the lifter pump and clean a mesh filter underneath 2 - remove the backplate on the fuel pump (where the inlet pipe joins the pump), and clean another mesh filter in there. Any other tips before I start working my way through the fuel system? On a seperate note (but possibly contributing to the issue) the air filter is one of these (foam filter inside). Is this standard? I have never been convinced it is what was meant to be on this engine.
Beta 1505 - injection pump timing
rgriffiths replied to rgriffiths's topic in Boat Building & Maintenance
Absolutely right - white smoke. And that is exactly what one of the mechanics said at the marina when he had a look at me trying to start it, although he claimed he didn't really know that much about engines. Only 40 years experience fixing them!! A 'bark' ... I will have a good listen. Thanks again
