Hi, am in process of battoning out the boat prior to spray foaming insulation. There are metal conduits down the side of the boat but I intend putting in wire ducting wherever I need wiring before the spraying. This is mainly the ends of the boat and down the middle.
I have two thoughts- put it in now...but is it better to use metal or pvc ducting, both seem available????
Or alternatively I tack wood where i want the wiring and then remove later leaving a clean area for wire ducting to be inserted later.??
I found the cable calculator thing very useful, will go and get the dual core wire and the ducting tomorrow,
And i should add do i want LSF coated or PVC sheathed or does it make no difference???
A
