wren
Everything posted by wren
Dangerous Towpaths - 'No Go' Area - Hackney
wren replied to ChrisJBrady's topic in Waterways News & Press
Indeed, the path as pictured no longer exists... -
(Giant's Other Half here.) We paid £170 for a 29" prop reconditioning nearly 2 years ago as part of the larger job of replacing the shaft, etc. Have had no problems with it since. T. Norris were super easy to deal with and very polite when it turned out the prop had been bodged onto the shaft with tar and cement.
The Other Half here -- I believe that's more gunk -- the sides look much cleaner now. (The unused tank on the other side is pitted in the sides. I think the previous woner may have coated the interior of one tank with something black.)
Hybrid generators: So how would I get the two shafts to engage?
wren replied to a topic in Boat Building & Maintenance
It's not grubby, it's historic! (The Other Half.) -
Aha! So if I need more Whitworth nuts, I should start unpicking Monkey's Fists?
The pump will kick in few minutes after the tap is opened (it depends on which tap & how much of course) and continues running for "a while" after the tap is closed. I will try to get more specific numbers, but that's all normal operation as I understand it. The original question is about the way the pump spontaneously runs without a tap being opened, though.
Neil: No dripping taps. First thing I checked.
What type of paint on top of epoxy - above & below waterline?
wren replied to Giant's topic in Boat Building & Maintenance
> Wren does fancy going back to Waddingtons colours. In honor of Victor Waddington's legendary thriftiness, however, I am prepared to wait until we've run out of the red and cream paint before reopening that debate. The (untouched since her working days) bollards I hope to repaint to appproximate original Waddy blue sooner than that. I had not thought about restoring the red on the front -- a bit hard now that it's all epoxy? -
At the moment, I am learning to accept what cannot be changed: the weather in the North Sea...
I certainly hope repairing it is an option! Because of the extremely peculiar nature of the mooring in London, it would be massively preferable to get to dry dock and on the mooring ASAP.
Sad morning here in Goole, last night we excavated a hairline crack on the port side of the engine block. (Not, I specify, on the top face, but on the side face.) So she won't be going to sea under her own engine, for sure. We really appreciate all the advice and time and help you've given us on this thread, and are pretty devastated that the sea journey isn't going to happen the way we had hoped. So now, I need advice on people able to repair cast iron and/or tugs for the North Sea...
I am remiss in thanking you (I can offer only that I have spent the last few days chained to the workbench in the engine room, cleaning mating surfaces...), it has cleared things up completely, thank you very much! We are now slowly getting to the point of reassembly...
I would really appreciate it since, having taken it all apart, the next job is to put it back together! Without leaks. Going off-manual makes me a little nervous.
To follow up, it looks like the hole for Stud A and the one to the right in previous pictures is a wider (3/8 W) threaded hole at the top, and then closes up to a narrower (5/16 W) threaded hole. Does anyone know (can this be extracted from the CAD model?) the original depth of the hole? We are wondering if we are dealing with an original hole which has been extended at a smaller thread or if there has been a helicoil inserted. (More precise visual identification is not really possible due to massive amounts of hardened bodging compound.)
Giant will be back in a little bit with the news and photos of the rest of the engine. I'm on cleaning detail tomorrow, armed with rags, a variety of brushes (nylon, brass, steel), a big red tin of GUNK, and WD-40. Any specific recommendations for cleaning, particularly the big studs still attached to the engine block and the vast amounts of red stuff we think is hardened haldite? It's red, it's solid, and it's all over the gaskets and block... My cleaning background is lab chemistry where we clean things with an ultrasonic bath and a variety of controlled solvents, all unavailable outside specialized laboratories.
Thanks for the wishes -- we've heard nothing from any of the possible skippers we're in touch with!
Road, er, canal trip! More seriously, without trying, how could we find out?
Other half here -- does that mean I can cross "paint and polish engine" off the rather lengthy "to-do-once-actually-living-aboard" list?
To add to the list, I have just purchased Goodwill (Harkers of Knottingley, 1953) and I note that Onward, sister ship to Forward is up fpr sale somewhere down south. (The listing suggests that she's been shortened.) Goodwill has a sister ship, Good Luck, according to this list: http://www.knottingley.org/history/harkerbuilt1.htm (number 259 and 260). Anyone know where Good Luck is?
I'm looking for recommendations for a surveyor who works in East Yorkshire. (For a hull survey of a Sheffield-sized boat.)
Keep thinking that, Jill... I have to catch a train from St Pancras early Monday morning of that weekend because I have to go to L'Orme des Merisiers Saint-Aubin which is miles from any boats (from this perspective, the facility at Daresbury was the best...the canteen overlooked the canteen and all the stressed scientists could wave at the happy narrowboaters). Otherwise, I am happy to turn up and look at boats etc.
To provide an update -- you can all stop flooding Jill with messages about me -- much common sense has been directed at me and I am rethinking my options (still very keen to see Misterton). However, I still need to find somewhere to live and I'd like it to be afloat if at all possible. The forums have been very helpful and friendly, and I thank you! Without exciting you all too much, are there any narrowboat owners in London who might like to show me their boats (there's only one at barking and I don't think it's a live-aboard) so's I can add that to the possibilities? Jill has invited me round to the Corbett but it will take a while to synchronize schedules.
Cough. I quote: "Insurance isn't required for Barking." I think that my insistence on a survey will scupper this... Your blog is an inspiration (a slightly terrifying one, mind). My partner and I would, by the way, love to see Misterton.
Done!
Not a problem, but can I receive PMs yet? Gosh, thank you for the offer! I don't think I can get to Nottingham before then as my boss has suggested that I'm putting a little too much flex in my flex time...of course from living on a barge that is being sold, I am aware that all serious buyers look at barges more than once, so maybe next time.
