Member Map
Calendar
Community Map
Everything posted by Markinaboat
Excellent! Enjoy NB Jack!
He'll have loads of info on the engine for you as he rebuilt it 🙂
For future reference, Charles Mills (ex Gardner) is located at Poynton 07712 052 635. Have been using hin for years, very meticulous. And of course Walshes in/near Manchester
Braunston Historic Boat Rally 2022
Markinaboat replied to David Schweizer's topic in History & Heritage
Yep. Also at the Cavalcade in Little Venice. unfortunately they're plugged in and quite a few of them. Shame as they're at the top of their game. -
Apparently they will be having duo's only as a friend of mine (Mandolin Monday) is not now playing there. -
New Eberspacher HS3 D4E installed..so quiet!
Markinaboat replied to Markinaboat's topic in Boat Equipment
I dont; think the audio on a video will be accurate enough to make a choice. Too many factors surroundng it. -
I'll be back at the boat one day next week at Braunston. Shame as been on it 7/24 since Friday. Pm me -
UPDATE: 376 trouble free hours. Boat is now at Braunston should anyone want a demo. depends on where you're based? -
Grit blast and epoxy in the South?
Markinaboat replied to Ewan123's topic in Boat Building & Maintenance
not sure David, it's what I was told. I guess a low-load trailer then they use several hydraulic jacks. -
If I were t get mine done, after much research n the last few years, Debdale really is the best bet. Temperature controlled, hoisted (not dragged on rollers), boat protected properly. They invested £m's in the facility. If you haven't got the time, consider a professional boat moved (a few on FB) then maybe you could just enjoy the trip back? Also approx 40% cheaper than down south as well. -
I wonder if it's worth asking the Wheatsheaf at Crick seeing as they always cater for the Crick show. Not on the same scale of course but they may be keen to get involved? -
a dodgy calculator or too much whisky?
Is the baseplate the usual 10mm or greater? If the latter, (maybe 12.5 or 15mm), I wonder if the 'fitter outer' took account of this when installing the ballast?
Have had two Nabru's over the years. Very comfy and am fussy, top quality foam which is easily replaceable after 2/3 years if required. Easy to put together too. Showroom in Uxbridge or at leats used to be. https://www.nabru.co.uk/
Would this damp concern you? Potential purchase
Markinaboat replied to northern's topic in General Boating
just had another look at 'Ellen', scroll down to the listings and it is flagged as sold. Needed a bit of work but wouldn't drop below £64k -
forgot to add that I believe Ellen was sold. -
Superb steel quality, Ellen has a 20mm baseplate and no ballast beneath. I came very close to buying her last year (deposit was paid) when she was for sale at Swanley Brokerage. Full hydraulic system for 2LW and thruster. -
I spoke with the broker who reckons Aga do buy-backs if I wanted rid of the stove. It's a Heritage UNO stove. They make double ovens as well (called the compact) which I have had. More than one heating engineer (domestic, not boat specific) have said they are the most reliable and easy to work on of all 'AGA' style oven/boilers. If I was looking for a boat and it had one of these, it would be a MAJOR buying point for me. (£5k new). Other than burning solid fuel, possibly the most relaible means of heating with cooking thrown in as a bonus. For summer, I would simply add a 1 or 2 burner gas hob. Probably already mentioned but Dennis Copper aka Canal Transport Services made superb hulls. -
Have had two ARS systems on different boats. One whined although not overly itimidating and did not distract from the 3LW, but there nonetheless. The other was quieter, more of a subdued hum that was drowned out by the JD3. Yes, thrusters can be used for longer but not a deal-breaker at all. A benefit of the hydraulic thruster is being less prone to blocking due to the screw being narrow as opposed to a propeller (guards can only prevent so much getting through), at least with the ARS version (made by Parker hydraulics IIRC). On the downside, you have very long, high-pressure hoses (20,000 psi?) which could burst and make one hell of a mess thoughout your boat so future servicing/inspection should be a criteria when making a decision. The main benefit of a hydraulically driven prop is that the engine can be sited anywhere as no need for a propshaft. This also provides for greater headrooom in any cabin aft of the engine. Overall I liked the hydraulic drive due to the full headroom in the engine room and boatmans cabin. But now, I like the simplicity of a PRM gearbox hanging off the end of my 2LW.
I think widebeams are restricted beyond Dunchurch Pools marina (going north). They have to book with CRT if they want to cruise between the marina and Braunston Turn.
Clean diesel or parrafin Martin. I used one or the other on your filter. Have fun putting it back in! Don't forget to completey disconnect the starter before wedging your hand in there against the crank!
Two very nice Steve Hudson boats: https://www.apolloduck.com/boat/steve-hudson-62-traditional-for-sale/667787 https://www.apolloduck.com/boat/hudson-57-traditional-for-sale/666609
This is the relatively new under-counter ‘wide’ model with a full size fridge and 4* freezer box. 113 litres in total. Have a new one and need to compare notes but this is model specific. https://boatfridge.co.uk/index.php/shop/rr4514-wide-fridge Thanks
have their been verified instances of this then Matt?
It was a special order Matt, direct fro Shoreline as had to wait 2/3 weeks. The replacement was built last Weds. Why would you think they would sell used fridges as new?
