Sarah and Ian Posted September 18, 2013 Report Share Posted September 18, 2013 Hello Mrs C has recently started to get her winter woolies out from under the bed. They all seem to have a musty smell not pungent but if you get up close its definitely there. These were vac bagged but some air had gotten into them. We have moisture traps under the bed and in the wardrobe. At the moment under the bed is sealed with no ventilation holes cut and the same for the wardrobe. Would it be woth cutting some holes to allow air to circulate?? Thanks in advance. Link to comment Share on other sites More sharing options...
Kae Posted September 18, 2013 Report Share Posted September 18, 2013 The short answer is yes! Any unventilated space will acquire moisture and will get that musty smell. Better still if you can get a flow of air, so ventilation at both ends/sides. Easy to smarten up with some vent covers or fancy wood covers. 1 Link to comment Share on other sites More sharing options...
Phil Ambrose Posted September 18, 2013 Report Share Posted September 18, 2013 Our wardrobe and under bed storage are ventilated with nice brass vents and 12v pooter fans wired into the lights, light on and large volume of air sucked outby fan, others have posted along similar vein. Phil Link to comment Share on other sites More sharing options...
Sarah and Ian Posted September 18, 2013 Author Report Share Posted September 18, 2013 The short answer is yes! Any unventilated space will acquire moisture and will get that musty smell. Better still if you can get a flow of air, so ventilation at both ends/sides. Easy to smarten up with some vent covers or fancy wood covers. Thanks to both for this. Would you put high and low level vents in the wardrobe?? Link to comment Share on other sites More sharing options...
Graham Davis Posted September 18, 2013 Report Share Posted September 18, 2013 Both, that way you get a through draft of air. Link to comment Share on other sites More sharing options...
Phil Ambrose Posted September 18, 2013 Report Share Posted September 18, 2013 Vents low down and fans as high as possible. Phil Link to comment Share on other sites More sharing options...
Kae Posted September 19, 2013 Report Share Posted September 19, 2013 Thanks to both for this. Would you put high and low level vents in the wardrobe?? Yes, so natural convection will help the ventilation also. I haven't yet (needed to) put computer fans to assist the ventilation as when I built the wardrobe I ensured there would be adequate ventilation, but I won't rule it out until we've seen how it goes over winter! Link to comment Share on other sites More sharing options...
Kristian Posted September 21, 2013 Report Share Posted September 21, 2013 Yes lots of holes, and i put a small rad in the wardrobe too. Link to comment Share on other sites More sharing options...
smileypete Posted September 21, 2013 Report Share Posted September 21, 2013 Plus make sure the wardrobe is lined with decent thickness of celotex on all and any 'cold' sides, louvered doors will help ventilation too. cheers, Pete. ~smpt~ Link to comment Share on other sites More sharing options...
Ex- Member Posted September 21, 2013 Report Share Posted September 21, 2013 We have under bed storage fully ventilated by drawing cool air from the bilge in summer. We also put all everyday clothes & materials in baskets that fit in shelf sections. Keeps stuff nice & fresh. The other side of the bed has a large pull out trolley where winter/summer stuff is stored, all stays fresh avoiding that awful musty smell. I was originally going to fit a door in front of the trolley, but ended up leaving it as it adds even more ventilation. Link to comment Share on other sites More sharing options...
