NorthwichTrader Posted August 6, 2013 Report Posted August 6, 2013 A friend of mine was showing me round his Ailsa Craig engine today, and I noticed it had oiler pots on the rocker covers. Should these have wicks in them, as does the kelvin engines, or are they just for an initial oiling prime? It seemed unlikely to me that these egg-cup sized pots were just for a one-off prime? Also, he was saying there were hot start sticks on the end of a screw in 'valve'...can you still obtain these 'things' you light? Many thanks, in advance...I can ask him more questions, if required, I just thought I'd start the ball rolling with this!
billh Posted August 6, 2013 Report Posted August 6, 2013 A friend of mine was showing me round his Ailsa Craig engine today, and I noticed it had oiler pots on the rocker covers. Should these have wicks in them, as does the kelvin engines, or are they just for an initial oiling prime? It seemed unlikely to me that these egg-cup sized pots were just for a one-off prime? Also, he was saying there were hot start sticks on the end of a screw in 'valve'...can you still obtain these 'things' you light? Many thanks, in advance...I can ask him more questions, if required, I just thought I'd start the ball rolling with this! The things you set fire to can be bought, I think, but you can make them yourself- did it about twenty years ago for our Ailsa craig RF2 loco engines. Rolled up blotting paper soaked in erm, erm, something solution ( might be saltpetre?) Leave to dry out and keep in a tin, they last for years. Starting method, take the "valves" out, insert the rollups, put a match to them, they glow like a cigarette, no flame or explosion, re-insert valves to engine, crank the engine de-compressed, then over compression and away she goes. Eazistart not required!!! We have 3 derelict RFR4s here- should be possible to get a good one from the 3, 40HP at 1200 rpm and 21/2 to 1 reduction box , a mighty powerful narrowboat engine. (This is not an advert by the way) Bill
NorthwichTrader Posted August 6, 2013 Author Report Posted August 6, 2013 The things you set fire to can be bought, I think, but you can make them yourself- did it about twenty years ago for our Ailsa craig RF2 loco engines. Rolled up blotting paper soaked in erm, erm, something solution ( might be saltpetre?) Leave to dry out and keep in a tin, they last for years. Starting method, take the "valves" out, insert the rollups, put a match to them, they glow like a cigarette, no flame or explosion, re-insert valves to engine, crank the engine de-compressed, then over compression and away she goes. Eazistart not required!!! We have 3 derelict RFR4s here- should be possible to get a good one from the 3, 40HP at 1200 rpm and 21/2 to 1 reduction box , a mighty powerful narrowboat engine. (This is not an advert by the way) Bill Thanks, Bill, I'll pass the info. on! Do you know anything about the oiling pots on the rocker covers?Is there any pumped oil to the rockers and valves, or are they dependant upon those oiler pots alone, as per the kelvin?
Timleech Posted August 6, 2013 Report Posted August 6, 2013 (edited) Self-igniting 'cigarettes' are also available, I think the brand is Zundfix. They are made in more than one diameter. Tim Edit to add link to a source Edited August 6, 2013 by Timleech
billh Posted August 6, 2013 Report Posted August 6, 2013 Thanks, Bill, I'll pass the info. on! Do you know anything about the oiling pots on the rocker covers? Is there any pumped oil to the rockers and valves, or are they dependant upon those oiler pots alone, as per the kelvin? The RF2s don't have the oilers, but they are classed as "Industrial " engines, they do have an oil feed from the pump, IIRC the feed is up one of the rocker shaft stands/bearings and along the hollow shaft and out through holes at each rocker. I will check on the RFR4s , the air intakes are part of the rocker cover castings so it could be the oilers are for priming the inlet valves and cylinders like on some Listers- increase the compression a bit for a cold start. The de-compressor lever on the front of the rocker cover also provides an "over compression" position for starting as well- return it to vertical as soon as it's running. Bill
by'eck Posted August 7, 2013 Report Posted August 7, 2013 Prompts me to ask did any older marine diesels have cartridge start as used with Field Marshall tractor engines? They also had lighted wick start assistance I believe.
Timleech Posted August 7, 2013 Report Posted August 7, 2013 Prompts me to ask did any older marine diesels have cartridge start as used with Field Marshall tractor engines? They also had lighted wick start assistance I believe. Lots of engines used the wick or cigarette system, precursors of glow plugs really. Kelvins (T series) used a 'HANSA' starter, which uses a strip of celluloid film, one cylinder head specially adapted, the rapid burning of the film creates pressure to push the piston down. Tim
johnthebridge Posted August 7, 2013 Report Posted August 7, 2013 (edited) Self-igniting 'cigarettes' are also available, I think the brand is Zundfix. They are made in more than one diameter. Tim Edit to add link to a source Unless they've stopped trading, J and R Starbuck, Gravesend. Real Aladdin's cave of boat bits you may have felt had been discontinued, including Zundfix starters. They might be computerised now, but I doubt it... Edited August 7, 2013 by johnthebridge
Timleech Posted August 7, 2013 Report Posted August 7, 2013 Unless they've stopped trading, J and R Starbuck, Gravesend. Real Aladdin's cave of boat bits you may have felt had been discontinued, including Zundfix starters. They might be computerised now, but I doubt it... Well they do have a basic web presence Tim
madcat Posted August 7, 2013 Report Posted August 7, 2013 Saltpetre and blotting paper roll ups, started Cuddington just fine in the days we were still at Ellesmere Port.
XAlan W Posted August 8, 2013 Report Posted August 8, 2013 Prompts me to ask did any older marine diesels have cartridge start as used with Field Marshall tractor engines? They also had lighted wick start assistance I believe. The Seffle I had in Lily had a screw in plug to take a Fag paper insert. I never used it as it also had a glow plug type device which heated via battery voltage there was also a plug that could be heated by blowlamp,gas torch etc. Was also fitted with a bleed off of compression when running to charge an air bottle for compressed air/compression starting
NorthwichTrader Posted August 8, 2013 Author Report Posted August 8, 2013 Self-igniting 'cigarettes' are also available, I think the brand is Zundfix. They are made in more than one diameter. Tim Edit to add link to a source Thanks, Tim, really appreciated! He was so pleased to be given this information, he'd all but given up himself! The RF2s don't have the oilers, but they are classed as "Industrial " engines, they do have an oil feed from the pump, IIRC the feed is up one of the rocker shaft stands/bearings and along the hollow shaft and out through holes at each rocker. I will check on the RFR4s , the air intakes are part of the rocker cover castings so it could be the oilers are for priming the inlet valves and cylinders like on some Listers- increase the compression a bit for a cold start. The de-compressor lever on the front of the rocker cover also provides an "over compression" position for starting as well- return it to vertical as soon as it's running. Bill Really appreciated, thanks again, Bill! Thanks also to madcat, Alan, and JohnTB, all helpful stuff! Cheers!
billh Posted August 8, 2013 Report Posted August 8, 2013 Thanks, Bill, I'll pass the info. on! Do you know anything about the oiling pots on the rocker covers? Is there any pumped oil to the rockers and valves, or are they dependant upon those oiler pots alone, as per the kelvin? Had a look at an RFR4 today, the oil cups are definitely into the air intake manifold, which is part of the rocker cover, so they are for cold starting , not lubricating the rockers. I would imagine a lot of smoke for a few minutes while the oil from these priming cups is burnt off! No wicks required . I would not fill these cups as that may cause excessive compression or even damage, perhaps about half full?
NorthwichTrader Posted August 9, 2013 Author Report Posted August 9, 2013 Had a look at an RFR4 today, the oil cups are definitely into the air intake manifold, which is part of the rocker cover, so they are for cold starting , not lubricating the rockers. I would imagine a lot of smoke for a few minutes while the oil from these priming cups is burnt off! No wicks required . I would not fill these cups as that may cause excessive compression or even damage, perhaps about half full?That's fantastic, many thanks for your help, Bill! I'm still SO impressed with the knowledge that can be accessed via this forum!Have a good weekend, Stuart
Timleech Posted August 9, 2013 Report Posted August 9, 2013 That's fantastic, many thanks for your help, Bill! I'm still SO impressed with the knowledge that can be accessed via this forum! Have a good weekend, Stuart While it pays to be cautious, engines that I have known with priming cups have had the cup sized to give the 'right' amount for cold starting, maybe half full if it's less cold. Tim
NorthwichTrader Posted August 10, 2013 Author Report Posted August 10, 2013 While it pays to be cautious, engines that I have known with priming cups have had the cup sized to give the 'right' amount for cold starting, maybe half full if it's less cold. Tim Cheers, Tim,Top feedback all round! Have a good evening all! Best regards, Stuart
