aread2 Posted July 17, 2007 Report Share Posted July 17, 2007 Has anybody got a Vetus water-lubricated stern tube fitted? What size is it? There seem to be an abundance of choices, pretty much made to order. What have you got? Link to comment Share on other sites More sharing options...
Guest Posted July 17, 2007 Report Share Posted July 17, 2007 Has anybody got a Vetus water-lubricated stern tube fitted? What size is it? There seem to be an abundance of choices, pretty much made to order. What have you got? Yes I have one such stern tube. Tell me what dimensions you need and i will measure tomorrow night. Link to comment Share on other sites More sharing options...
chris w Posted July 17, 2007 Report Share Posted July 17, 2007 me too - info needed as per Catweasel Chris Link to comment Share on other sites More sharing options...
aread2 Posted July 18, 2007 Author Report Share Posted July 18, 2007 Can you give me : Complete prop shaft length (probably different for each boat, 1000, 1500, 2000 or 2500mm originally) length of tube itself (ends somewhere in the rubber boot, 500, 1000, 1500 or 2000mm) Prop shaft diameter (30mm?) Link to comment Share on other sites More sharing options...
Guest Posted July 18, 2007 Report Share Posted July 18, 2007 Can you give me :Complete prop shaft length (probably different for each boat, 1000, 1500, 2000 or 2500mm originally) length of tube itself (ends somewhere in the rubber boot, 500, 1000, 1500 or 2000mm) Prop shaft diameter (30mm?) will measure tomorrow (thursday) Link to comment Share on other sites More sharing options...
stuart Posted July 19, 2007 Report Share Posted July 19, 2007 Just a note but I think all the vetus stuff is metric as well. Think my prop shaft is 35mm - with a vetus water lub. Link to comment Share on other sites More sharing options...
