hilaryb 2 Posted November 8, 2016 Report Share Posted November 8, 2016 whats the best way to attach small tyres to the side of the boat as extra fenders, folks. I,have said tyres and rope,so far. Link to post Share on other sites
Tony Brooks 3119 Posted November 8, 2016 Report Share Posted November 8, 2016 Hooks for the handrail. You can buy ready made ones for the angle iron trad style handrails and I made mine for the pipe style from strip steel using a blowlamp an home made jig. Link to post Share on other sites
Jak 22 Posted November 8, 2016 Report Share Posted November 8, 2016 Ajax has some neat rings on the flanks and the ropes for the fenders clip on. I didn't do it but it works well. So mean that I only have two so the crew have to move them over for whichever side we are mooring! Link to post Share on other sites
Guest Posted November 8, 2016 Report Share Posted November 8, 2016 Hooks for the handrail. You can buy ready made ones for the angle iron trad style handrails and I made mine for the pipe style from strip steel using a blowlamp an home made jig. That is how we hang tyres on when moored. I drilled the tyres and threaded rope through, with wooden blocks on the inside to stop rope and knot pulling out. Link to post Share on other sites
PeterDHS 9 Posted November 8, 2016 Report Share Posted November 8, 2016 Top fix depends on whether you have rails or gutters. At the tyre end drill 8 to 10 mm holes once at top and two at bottom 75mm apart. Thread lorry rope down thru top hole, out thru one bottom hole' in thru other bottom hole and knot securely. This ensures that pressure/strain transfers to a wide and protected portion of tread whilst the knot is safely away from chaffes. Mine are still good at over five years, although the rubber (ex go-cart best) is perishing. Link to post Share on other sites
