clintonr Posted January 29, 2015 Report Share Posted January 29, 2015 (edited) I have noticed a very very small amount of water around the bleed screw on my skin tank I recently changed the antifreeze in the engine. What type of washer can I use to create a water tight seal. I used the old washer and can't remember what type in is. Edited January 29, 2015 by clintonr Link to comment Share on other sites More sharing options...
The Bagdad Boatman (waits) Posted January 30, 2015 Report Share Posted January 30, 2015 (edited) any copper or fiber washer will do it is a low temperature fitting. Edited January 30, 2015 by The Bagdad Boatman (waits) Link to comment Share on other sites More sharing options...
trackman Posted January 30, 2015 Report Share Posted January 30, 2015 Would some PTFE tape on the threads help too? Link to comment Share on other sites More sharing options...
DHutch Posted January 31, 2015 Report Share Posted January 31, 2015 O-ring? Bit of polyurethane or loctite black silicon? Daniel Link to comment Share on other sites More sharing options...
blackrose Posted January 31, 2015 Report Share Posted January 31, 2015 (edited) Would some PTFE tape on the threads help too? Get the gas PTFE. It's thicker and easier to apply. Can also be used on threads for water systems. http://www.wickes.co.uk/Wickes-PTFE-Gas-Tape-12mm-x-5m/p/420073 It's all I have on my bleed screw - no washer. Edited January 31, 2015 by blackrose Link to comment Share on other sites More sharing options...
