geoffwales Posted August 31, 2013 Report Share Posted August 31, 2013 Sorry not sure which section this should go. I have a viking cruiser and want to fit a shower, the problem is the current cubicle cannot be accessed underneath so what i was thinking was getting a shower tray that doesnt have the plug hole in it so i can fit a small 15mm skin fitting drain with a 90deg elbow straight out to the side into a pump. Does anyone know where a could get such a tray where the hole hasnt been put in. Geoff Link to comment Share on other sites More sharing options...
furnessvale Posted August 31, 2013 Report Share Posted August 31, 2013 Sorry not sure which section this should go. I have a viking cruiser and want to fit a shower, the problem is the current cubicle cannot be accessed underneath so what i was thinking was getting a shower tray that doesnt have the plug hole in it so i can fit a small 15mm skin fitting drain with a 90deg elbow straight out to the side into a pump. Does anyone know where a could get such a tray where the hole hasnt been put in. Geoff I know quite a few in the working boat fraternity who stand in a Gorilla bucket:-) George ex nb Alton retired Link to comment Share on other sites More sharing options...
Graham Bowers Posted August 31, 2013 Report Share Posted August 31, 2013 I ended up making one for my cruiser so I could get the exact size to convert my "little room" to a wetroom. I removed the floor and replaced it with the tray, so did have access underneath - I fibreglassed a 22mm elbow in to the hole in the base of the tray to minimise the under floor height needed and attached a hose from the elbow to a whale gulper. I think if you come in from the side, you will always end up with water left in the tray that you will need to sponge out. If I were you I'd make a mockup up of your proposed drain concept using a plastic storage box and see how it works. Not really an answer to your question, but hopefully food for thought. Graham Link to comment Share on other sites More sharing options...
geoffwales Posted August 31, 2013 Author Report Share Posted August 31, 2013 Thinking of making my own fibreglass tray Link to comment Share on other sites More sharing options...
pelicanafloat Posted August 31, 2013 Report Share Posted August 31, 2013 If you want to make your own ..... Why not use some waterproof 3/4" ply, and then tile it with non slip tiles and incorporate a tile up stand to make it look proper like :-) Link to comment Share on other sites More sharing options...
Phil Ambrose Posted August 31, 2013 Report Share Posted August 31, 2013 Or why not use marine ply and "lay it up" with GRP finishing it of with a nice gel-coat layer,done correctly iy will look great. Phil Link to comment Share on other sites More sharing options...
Phil Ambrose Posted September 1, 2013 Report Share Posted September 1, 2013 Met a pal this morning who proudly showed me a new shower tray he had just got off Ebay, it had NO drain hole, so check out Ebay. Phil Link to comment Share on other sites More sharing options...
Graham Bowers Posted September 1, 2013 Report Share Posted September 1, 2013 Or why not use marine ply and "lay it up" with GRP finishing it of with a nice gel-coat layer,done correctly iy will look great. Phil That's what I did with one small but important difference. Don't use gel coat, use flow coat. Flow coat is like gel coat but has wax added and it goes off in contact with air. Gel coat is designed to be put in a mould first. If gel coat is used as a top coat and is in contact with air, it stays tacky. Graham Link to comment Share on other sites More sharing options...
geoffwales Posted September 1, 2013 Author Report Share Posted September 1, 2013 As luck would have it i decided to rip the carpet up inthe toilet and it has a preformed shower tray, only problem is it has tons of glue on it Link to comment Share on other sites More sharing options...
Phil Ambrose Posted September 1, 2013 Report Share Posted September 1, 2013 Never come across Floe Coat but have done loads of repairs to Gel Coat and the repairs have gone off OK and by the time I'd finished you would be hard pressed to tell where the repair was done. I am aware of how a GRP boat is laid up having worked at Brooms and spent time at Connoisseur Cruisers but never came across Flow Coat, my education must be lacking,they do say we never stop learning. Phil Link to comment Share on other sites More sharing options...
