A different approach to solar and batts etc
Sounds good, didn't know it did SoC too.
So when more than 100% of the Ah reading is put back into the batts, does the Ah stay at zero or does it count past zero into a negative number? I'd expect the SoC stays at 100% in either case.
cheers, Pete.
~smpt~
its ah left not ah used so on recharge it only counts up to the battery maximum.
Hi I realised years ago full traction batteries and a lot of them is the way to go. Now I dont look at meters etc and use as much power as I want In the long run with batteries buying the best gets you the best.
Peter
