Alastair Posted May 10, 2013 Report Share Posted May 10, 2013 We need to get a hull survey done on our barge. Haulout on our waterway is very difficult - basically we are looking at having to arrange crane hire for a day. Any nearby locations where we could be craned out aren't suitable for repair work either. Has anyone here had an in-water hull survey done? Who did you use and what were the costs? Link to comment Share on other sites More sharing options...
The Bagdad Boatman (waits) Posted May 10, 2013 Report Share Posted May 10, 2013 It may be difficult to judge the degree of corrosion in a hull. To use the thickness tester the surveyor grinds the hull clear of gunge in small patches. What about Waddingstons old dry dock at Castleford. Link to comment Share on other sites More sharing options...
Grace and Favour Posted May 10, 2013 Report Share Posted May 10, 2013 It may be difficult to judge the degree of corrosion in a hull. To use the thickness tester the surveyor grinds the hull clear of gunge in small patches. What about Waddingstons old dry dock at Castleford. Now known as Supreme Marine - - Here's Ian's contact details: Supreme Marine Link to comment Share on other sites More sharing options...
Alastair Posted May 10, 2013 Author Report Share Posted May 10, 2013 Their dock looks large enough. I'm out of touch with the routes these days - can you get to castleford via goole? I'm pretty sure Selby is no good for us. It's quite an investment in time to get to Castleford - a full day to Goole (realistically, allowing for tide). Then probably the same to castleford. So 4 days to get there and back. I guess nobody here has had underwater surveys done. I know it's possible and is done on ships all the time. Link to comment Share on other sites More sharing options...
Grace and Favour Posted May 10, 2013 Report Share Posted May 10, 2013 The yard is on the Air & Calder Navigation - - and as the gravel barges manage OK - I think you should!! What size are you (well - - not you, of course, but your boat!) Link to comment Share on other sites More sharing options...
Alastair Posted May 10, 2013 Author Report Share Posted May 10, 2013 erm, trying to remember rough dimensions. Hull just under 5m beam - but we have leeboards that add about 30cm each side. Length - 19.7m honest then there is the rudder (about 3m) and the non-retractable bit of the bowsprit - about 3m So say 5.7m beam max and max overall length 27m. Air draft is about 3.5m with the mast down. I have a bit of work to do - the poor thing has been neglected for too long and needs some TLC, including new canvas. Link to comment Share on other sites More sharing options...
Naughty Cal Posted May 10, 2013 Report Share Posted May 10, 2013 Take you surveyor with you and beach it at Nun Monkton. Make sure you can get back off again mind........ Link to comment Share on other sites More sharing options...
Alastair Posted May 10, 2013 Author Report Share Posted May 10, 2013 Might be a bit difficult to ensure that the water drops and raises conveniently! Link to comment Share on other sites More sharing options...
Naughty Cal Posted May 10, 2013 Report Share Posted May 10, 2013 No need for it to drop. Drive it at the beach and get enough out of the water for him/her to have a look at. Just make sure you leave the stern in the water otherwise you will have to wait until it rains to get back off again.......... Link to comment Share on other sites More sharing options...
Alastair Posted May 10, 2013 Author Report Share Posted May 10, 2013 They need to get under the boat for a hull survey. Maybe I could dig a trench and ask them to lie in it as I drive the boat up the beach? Link to comment Share on other sites More sharing options...
Naughty Cal Posted May 10, 2013 Report Share Posted May 10, 2013 Is the boat entirely flat bottomed? I expect not. On a more serious note you either need a crane or are going on long journey to find a dry dock if you dont want to beach it somewhere. Link to comment Share on other sites More sharing options...
mrsmelly Posted May 10, 2013 Report Share Posted May 10, 2013 (edited) erm, trying to remember rough dimensions. Hull just under 5m beam - but we have leeboards that add about 30cm each side. Length - 19.7m honest then there is the rudder (about 3m) and the non-retractable bit of the bowsprit - about 3m So say 5.7m beam max and max overall length 27m. Air draft is about 3.5m with the mast down. I have a bit of work to do - the poor thing has been neglected for too long and needs some TLC, including new canvas. You would get to Castleford with ease although air draught is lower in some places than others such as whitley bridge. You say 3.5m and I dont have a clue what that is in English. You can get 200 feet by 20 feet to Cas no problems and the dock unless its been made smaller will cope . Tim Edited May 10, 2013 by mrsmelly Link to comment Share on other sites More sharing options...
Grace and Favour Posted May 10, 2013 Report Share Posted May 10, 2013 You would get to Castleford with ease although air draught is lower in some places than others such as whitley bridge. You say 3.5m and I dont have a clue what that is in English. You can get 200 feet by 20 feet to Cas no problems and the dock unless its been made smaller will cope . Tim Cas is big enough for OP's Link to comment Share on other sites More sharing options...
Alastair Posted May 10, 2013 Author Report Share Posted May 10, 2013 Is the boat entirely flat bottomed? I expect not. On a more serious note you either need a crane or are going on long journey to find a dry dock if you dont want to beach it somewhere. Hence the interest in in-water hull surveys. A long journey isn't free and dry docks are expensive up this way. Link to comment Share on other sites More sharing options...
