AllanW Posted July 26, 2006 Report Share Posted July 26, 2006 Hi guys... I'm just in the preliminary stages of planning a boat If the new limitations on use of red diesel do indeed come into force at the end of the year - would it be worth considering planning now to have seperate red and white diesel tanks fitted at the build stage?(assuming that we will still be able to use red for heating) Thoughts anyone? Allan Link to comment Share on other sites More sharing options...
GUMPY Posted July 26, 2006 Report Share Posted July 26, 2006 Hi guys... I'm just in the preliminary stages of planning a boat If the new limitations on use of red diesel do indeed come into force at the end of the year - would it be worth considering planning now to have seperate red and white diesel tanks fitted at the build stage?(assuming that we will still be able to use red for heating) Thoughts anyone? Red will be OK for power generation and heating. I had my second tank fitted in 2004 to beat the "rush" definately go for a second tank anyway if the derrogation does continue then all that it will mean is that you will have increased capacity and if you can get it up to 600L ( 500 + 100 left) this will mean that you can have a tanker delivery rather than pay marina prices. J Link to comment Share on other sites More sharing options...
bottle Posted July 26, 2006 Report Share Posted July 26, 2006 Hi Allan You have nothing to lose by fitting two tanks, the extra cost if any at the new build stage will be minimul, I shall be having twin tanks when mine is built. Link to comment Share on other sites More sharing options...
Gary Peacock Posted July 26, 2006 Report Share Posted July 26, 2006 All our boats have two tanks we took the decision to do this 3 years ago when the Red fuel saga first became common knowledge. Link to comment Share on other sites More sharing options...
Guest Grant Posted August 2, 2006 Report Share Posted August 2, 2006 I had two tanks fitted. It was an extra 200 quid. Link to comment Share on other sites More sharing options...
elessina Posted August 2, 2006 Report Share Posted August 2, 2006 would it be worth considering planning now to have seperate red and white diesel tanks fitted at the build stage Allan If you intend to live aboard then yes, definitely. If you spec it before you get quotes, likely it will be included for very little extra cost. Ask for it after you place an order, and the chances are it will cost you a few hundred pound!!!. If you do not intend to live aboard and only use a heater for a small amount of time (using small quantities of fuel) then the hassle of having two separate tanks may not be worth the agro. Even if / when the red 'marine' diesel goes, I can not imagine many, if any, marinas will have two diesel pumps, so likely you would have to carry the 'heating' diesel to your boat….. 5 gallons a time, saving £12!….. too easy to fill up with white at the marina whilst you fill your engine tank!!!!, I think if a low user most will fill up at the marina…… and not so easy to find somewhere even now away from marinas selling red / heating fuel, most garages do not sell it. But yes, definitely two tanks if live aboard. Ian Elessina Link to comment Share on other sites More sharing options...
ChrisPy Posted August 2, 2006 Report Share Posted August 2, 2006 … and not so easy to find somewhere even now away from marinas selling red / heating fuel, most garages do not sell it. may be worth specifying a really big tank, like a home heating oil tank, and arrange for the distributor to visit you somewhere where he can fill you directly from his tanker truck. what is the minimum delivery quantity? probably only need it once a year. Link to comment Share on other sites More sharing options...
elessina Posted August 2, 2006 Report Share Posted August 2, 2006 what is the minimum delivery quantity? I have been advised that it is 500 litres..... thats a lot for a narrowboat!, especialy if having two tanks. No problem on a wide beam, where the space under floor is normally around 18" deep. Ian Link to comment Share on other sites More sharing options...
GUMPY Posted August 2, 2006 Report Share Posted August 2, 2006 may be worth specifying a really big tank, like a home heating oil tank, and arrange for the distributor to visit you somewhere where he can fill you directly from his tanker truck. what is the minimum delivery quantity? probably only need it once a year. 500litres is the minimum There is ususlly a decent price break at 1000L As for once a year well most winters I get through 1100L with ease, so I guess its at least twice a year for me. If we loose red then I will be putting a tank of at least 1500L on the moorings for my heating as most fuel suppliers will not deliver directly to boats. J Link to comment Share on other sites More sharing options...
ChrisPy Posted August 3, 2006 Report Share Posted August 3, 2006 I will be putting a tank of at least 1500L on the moorings I can't believe that is acceptable to the authorities in most locations. Link to comment Share on other sites More sharing options...
GUMPY Posted August 3, 2006 Report Share Posted August 3, 2006 I can't believe that is acceptable to the authorities in most locations. There are things you have to do It wont just be a single skinned tank as it will be within 10m of the canal (despite being 2m below the canal level) it will be a "bunded" tank i.e. a tank within a tank to comply with regs. I could go to 2300L but felt that was a bit excessive. If it was more than 10m away from a watercourse in most locations you can get away with a single skinned tank, however I think that is chancing it a bit. Remeber its not a commercial premisis so different rules apply. J Link to comment Share on other sites More sharing options...
ChrisPy Posted August 3, 2006 Report Share Posted August 3, 2006 There are things you have to do It wont just be a single skinned tank as it will be within 10m of the canal (despite being 2m below the canal level) it will be a "bunded" tank i.e. a tank within a tank to comply with regs. I could go to 2300L but felt that was a bit excessive. If it was more than 10m away from a watercourse in most locations you can get away with a single skinned tank, however I think that is chancing it a bit. Remeber its not a commercial premisis so different rules apply. J and I'm sure you'll need planning permission, the landowner's permission, etc. Link to comment Share on other sites More sharing options...
GUMPY Posted August 3, 2006 Report Share Posted August 3, 2006 and I'm sure you'll need planning permission, the landowner's permission, etc. Land owners permission I have Planning permission not needed if its a residential site. J Link to comment Share on other sites More sharing options...
ChrisPy Posted August 4, 2006 Report Share Posted August 4, 2006 Land owners permission I have Planning permission not needed if its a residential site. J lucky you. will you also supply red gas oil to other boaters? Link to comment Share on other sites More sharing options...
GUMPY Posted August 4, 2006 Report Share Posted August 4, 2006 lucky you. will you also supply red gas oil to other boaters? No because then I have to register with HMCE and it becomes commercial...... The only reason for fitting a tank is that there are very few tankers that will deliver to boats directly even when I can take 1000L so a tank gets round this. J Link to comment Share on other sites More sharing options...
