alan_fincher Posted December 12, 2005 Report Share Posted December 12, 2005 I've had many recommendations to use RTV (Room Temperature Vulcanising) Silicone Sealant. But ringing miltiple DIY Suppliers / Hardware Supplies / Builders Merchants has drawn a total blank. "Yes, they stock silicone sealants", "No, They have never heard of RTV". Best I found was somewhere that could order it in, but minimum order to them avout £750 worth (!) I can't even seem to find a mail order supplier. Any ideas, please ? Does anyone have brand names, which maybe, just maybe, might mean more to someone than RTV ? How much less good is it to use just any Silicone Sealant? It was suggested to me that it must be "Neutral Cure", because "Acetic cure", (I think) could damage the window frames. Does that make sense, please, and how do I know what I've bought ? Link to comment Share on other sites More sharing options...
Moley Posted December 12, 2005 Report Share Posted December 12, 2005 Well correct me if I've ballsed-up, but I've used regular exterior grade silicone sealants from B&Q, around 3 to 4 quid a tube. If it says it's for exterior use, wood, metal or plastics, and has some flexibility, then what's the difference? It's not like I'm ever going to take our boat into a marine environment. Ade. Link to comment Share on other sites More sharing options...
ChrisPy Posted December 12, 2005 Report Share Posted December 12, 2005 I think we've got an RHT here. Red Herring Thread. If silicone goes off at room temperature then presumably that classifies it as RTV. And all the silicones you buy at the DIY store will be like that. Link to comment Share on other sites More sharing options...
Richard Bustens Posted December 12, 2005 Report Share Posted December 12, 2005 What are you trying to stick with it Alan Link to comment Share on other sites More sharing options...
alan_fincher Posted December 12, 2005 Author Report Share Posted December 12, 2005 What are you trying to stick with it Alan I'm about to rebed a leaking window. So anodised aluminium bedding on to steel, (hopefully painted steel, if I can actually get any to dry at current temperatures!...). Window held by screws passing through holes in cabin side into wood battens behind. Maybe it is a Red Herring, but both John and Daniel have suggested that RTV is best. I can see it's made, find places that will sell me £750 worth (!), but nobody seems to want to sell me a couple of tubes. I can by a normal Silicone sealant that is "one part neutral curing low modulus" from a local window suppliers (at only £2 per cartridge). I've used some of that on a temporary job today. It was quite runny, and showed little sign of going off some trime after I had applied it. Not really convinced its going to be what I need under the window, but it might be OK. An alternative, at my chandlery would be something called Sikaflex 291 - it's not a silicone - it's polyurethane based. It would seem OK although it doesn't mention windows, but says it should not be applied under 10 degrees C, and it's never that warm here, at the moment.... Link to comment Share on other sites More sharing options...
DHutch Posted December 12, 2005 Report Share Posted December 12, 2005 It may well be a redherring, all i know is that in our local DIY shop they stock sealent which calls itself RTV silicon, which advertises itself external use. - And is 50p more than the std "contains silicon" bathroom and frame sealents they stock. - And was recomend by the guy at the till and being better than the others (which basical arnt silicon at all) So maybe most silicon sealents are the same, and equally good? - Obvouly the whole "contains Silicon" is a bit omunous!! They also stock a polyurethene sealent (not sikaflex), which can be painted over. Daniel Link to comment Share on other sites More sharing options...
Amicus Posted December 12, 2005 Report Share Posted December 12, 2005 Not sure this helps http://www.techsil.co.uk/GE-C-5-Pro-si-gen.html Link to comment Share on other sites More sharing options...
DHutch Posted December 12, 2005 Report Share Posted December 12, 2005 Not sure this helps http://www.techsil.co.uk/GE-C-5-Pro-si-gen.html So basicaly its all RTV, if its silicon at all. Link to comment Share on other sites More sharing options...
Richard Bustens Posted December 13, 2005 Report Share Posted December 13, 2005 Well i used the stuff from B&Q 6 tubes in a pack for £15 i have used it for sticking in windows sealing roof vents and putting on tiles and im'e pretty sure they wont be coming off. Also when i seal windows i put a bead on the surface and let it go off to make a flexable gasket so when you fit the frame it compreses the bead to make a good tight seal, then just a tiny bit on top when fitting just to make a sticky seal. Link to comment Share on other sites More sharing options...
