W+T Posted March 29, 2010 Report Share Posted March 29, 2010 (edited) This is a Q for those who are in the know on central heating plumbing on boats using a back boiler. What does the central heating system consist of when using a back boiler on a stove, what will i need to set one up to run of a boiler of no specific stove for a single radiator, are they pressured systems or open vented etc etc . All advice welcome as always wayne Edited March 29, 2010 by W+T Link to comment Share on other sites More sharing options...
Robbo Posted March 29, 2010 Report Share Posted March 29, 2010 (edited) Open vented, copper pipes (28mm min) for gravity system, radiator(s) big enough to take heat away, header tank. Optional pump. There was a recent conversation with a diagram in... Edit; found http://www.canalworld.net/forums/index.php?showtopic=25064 Edited March 29, 2010 by Robbo Link to comment Share on other sites More sharing options...
bottle Posted March 29, 2010 Report Share Posted March 29, 2010 One radiator? It will need to be a very small boiler or a very large radiator. Boiler needs to match radiators output or the other way round. Link to comment Share on other sites More sharing options...
W+T Posted March 30, 2010 Author Report Share Posted March 30, 2010 One radiator? It will need to be a very small boiler or a very large radiator. Boiler needs to match radiators output or the other way round. So for a radiator of 18 inch x 24 inch what size boiler would i need? thanks for that info mate. Link to comment Share on other sites More sharing options...
alan_fincher Posted March 30, 2010 Report Share Posted March 30, 2010 So for a radiator of 18 inch x 24 inch what size boiler would i need? thanks for that info mate. I'm guessing that if you can only accommodate one radiator, and that is the maximum size, you would struggle to find a small enough back boiler, as that rad will not be able to dissipate the heat fast enough ? Obviously a double panel radiator, with finning, would dump heat faster than an unfinned single panel of the same size, but I still feel it would not be enough. I'm happy to be told I'm wrong though, as I've never tried it! Link to comment Share on other sites More sharing options...
bottle Posted March 30, 2010 Report Share Posted March 30, 2010 Info gained from Screwfix: http://www.screwfix.com/prods/37677/Plumbi...mm-1743Btu-511W As you can see this is rated at 511 watts (½Kw) http://www.screwfix.com/prods/49023/Plumbi...tor-600-x-400mm and this one at 380 watts (⅓ Kw) Now I am not a heating engineer but even with losses in the system, I suspect that a boiler of 1000 watts (1 Kw) would be to big. Willing to be corrected obviously. Link to comment Share on other sites More sharing options...
W+T Posted March 31, 2010 Author Report Share Posted March 31, 2010 So then, what size boilers do you have on your stoves, and what/how many rads do you have, i am on palnning to make my own boiler so i can make it what ever size ai need, if it needs to be a size that wont work fair enough but no harm in trying. Could even do under floor heating, will take more heat out of the system Link to comment Share on other sites More sharing options...
Robbo Posted March 31, 2010 Report Share Posted March 31, 2010 Could even do under floor heating, will take more heat out of the system Remember underfloor heating requires a lower water temperature than radiators, mainly due to warping the floor.. Link to comment Share on other sites More sharing options...
bottle Posted March 31, 2010 Report Share Posted March 31, 2010 I do not have a back boiler. I have a Morsø Squirrel rated at 6Kw maximum output in a sixty foot narrowboat and not run it above 'tick-over' since last August. Link to comment Share on other sites More sharing options...
W+T Posted March 31, 2010 Author Report Share Posted March 31, 2010 Remember underfloor heating requires a lower water temperature than radiators, mainly due to warping the floor.. Wasnt serious mate. , my god imagine walking on a radiator LOL Link to comment Share on other sites More sharing options...
Robbo Posted March 31, 2010 Report Share Posted March 31, 2010 (edited) Wasnt serious mate. , my god imagine walking on a radiator LOL I'm looking at underfloor heating for my boat! Edited March 31, 2010 by Robbo Link to comment Share on other sites More sharing options...
