grandunion5 Posted October 20, 2009 Report Share Posted October 20, 2009 Hi there. Is it a good idea to fuse the positive wire going from the starter battery to the starter solenoid? And if yes, what sort of amps should it be? Thanks Marc Link to comment Share on other sites More sharing options...
Chris Pink Posted October 20, 2009 Report Share Posted October 20, 2009 It's not standard practice but it is good practice and it would be a mega fuse or suchlike in the region of 4-500A - you will be probably using somewhere around 300A to turn the starter. Mind whether a fuse would prevent a fire started by a wiring fault that passed that kind of current is debatable (and probably will be). Link to comment Share on other sites More sharing options...
Robbo Posted October 20, 2009 Report Share Posted October 20, 2009 It's not standard practice but it is good practice and it would be a mega fuse or suchlike in the region of 4-500A - you will be probably using somewhere around 300A to turn the starter. Mind whether a fuse would prevent a fire started by a wiring fault that passed that kind of current is debatable (and probably will be). 300+ amps seems alot for a starter solenoid, sounds like your mixing up with the motor. Think my car has around 30-40 amp fuse for solenoid. Link to comment Share on other sites More sharing options...
Chris Pink Posted October 20, 2009 Report Share Posted October 20, 2009 300+ amps seems alot for a starter solenoid, sounds like your mixing up with the motor. Think my car has around 30-40 amp fuse for solenoid. You could be right, I may have misinterpreted the OP, if so, then 35A is about right for the fuse to the 'ignition' key. Link to comment Share on other sites More sharing options...
Tony Brooks Posted October 20, 2009 Report Share Posted October 20, 2009 You could be right, I may have misinterpreted the OP, if so, then 35A is about right for the fuse to the 'ignition' key. I read it the same as you did Chris. Otherwise the OP would almost certainly said from the ignition switch to battery. Link to comment Share on other sites More sharing options...
grandunion5 Posted October 20, 2009 Author Report Share Posted October 20, 2009 Thanks for the replies. I am the one who made a mistake as I should have said starter motor indeed. Fuses to the ignition key are in place in the engine loom. Marc Link to comment Share on other sites More sharing options...
