grahoom Posted August 19, 2009 Report Share Posted August 19, 2009 Hello, I am looking for some data feeds for tide times - I contacted UKHO but they said they are not in a position to help me. They provide the service - http://easytide.ukho.gov.uk/EasyTide/EasyTide/index.aspx - which essentially has the DATA i need. Does anyone else know of a service similar to this? cheers graham Link to comment Share on other sites More sharing options...
howardang Posted August 19, 2009 Report Share Posted August 19, 2009 Hello, I am looking for some data feeds for tide times - I contacted UKHO but they said they are not in a position to help me. They provide the service - http://easytide.ukho.gov.uk/EasyTide/EasyTide/index.aspx - which essentially has the DATA i need. Does anyone else know of a service similar to this? cheers graham Here are two more sites which you may find useful. http://www.bbc.co.uk/weather/coast/tides/ http://www.pol.ac.uk/ntslf/tidalp.html Most ports aropund the coast also provide tide information - the larger ones via their VTS systems. As an example, here is the one for my local one - ABP Humber. http://www.humber.com/ I hope this is useful. Howard Link to comment Share on other sites More sharing options...
grahoom Posted August 19, 2009 Author Report Share Posted August 19, 2009 Here are two more sites which you may find useful. http://www.bbc.co.uk/weather/coast/tides/ http://www.pol.ac.uk/ntslf/tidalp.html Most ports aropund the coast also provide tide information - the larger ones via their VTS systems. As an example, here is the one for my local one - ABP Humber. http://www.humber.com/ I hope this is useful. Howard Hello Howard, the BBC use data from UKHO POL looks like a good source. thanks for the link. graham Link to comment Share on other sites More sharing options...
GUMPY Posted August 19, 2009 Report Share Posted August 19, 2009 Hello, I am looking for some data feeds for tide times - I contacted UKHO but they said they are not in a position to help me. They provide the service - http://easytide.ukho.gov.uk/EasyTide/EasyTide/index.aspx - which essentially has the DATA i need. Does anyone else know of a service similar to this? If its London Area then http://www.pla.co.uk/display_fixedpage.cfm...1/site/maritime gives you all you need to know Or http://www.wxtide32.com/ will give you a program that will calc it for you having said that his disclaimer is good: Do not rely on the output of this program for decisions that can result in harm to any person or property. There is no way to provide certified data on a zero budget so if you need guaranteed results then WXTide32 is not for you. But its within a few minutes either way Link to comment Share on other sites More sharing options...
