Liam Posted July 16, 2008 Report Share Posted July 16, 2008 I've just done a quick search online for a replacement fuel lift pump for a Perkins D3 and it appears there are two types. One of them has a short, wide arm, and the other has a long, thin arm. Does anybody know which one I will need as a replacement? I'm guessing it will depend on whatever type the engine is geared for but I bought one a couple of years ago from a local shop (none boaty) no questions asked and it fitted and was okay. Unfortunately the receipt is on the boat so I can't get any part numbers or any other info... Link to comment Share on other sites More sharing options...
Bones Posted July 16, 2008 Report Share Posted July 16, 2008 I've just done a quick search online for a replacement fuel lift pump for a Perkins D3 and it appears there are two types. One of them has a short, wide arm, and the other has a long, thin arm. Does anybody know which one I will need as a replacement? I'm guessing it will depend on whatever type the engine is geared for but I bought one a couple of years ago from a local shop (none boaty) no questions asked and it fitted and was okay. Unfortunately the receipt is on the boat so I can't get any part numbers or any other info... take the old one off and have a look. That is what I had to do with mine. Link to comment Share on other sites More sharing options...
buggsy Posted July 30, 2008 Report Share Posted July 30, 2008 I've just done a quick search online for a replacement fuel lift pump for a Perkins D3 and it appears there are two types. One of them has a short, wide arm, and the other has a long, thin arm. Does anybody know which one I will need as a replacement? I'm guessing it will depend on whatever type the engine is geared for but I bought one a couple of years ago from a local shop (none boaty) no questions asked and it fitted and was okay. Unfortunately the receipt is on the boat so I can't get any part numbers or any other info... Hi Liam, sorry for the late reply but i have been away for two weeks, the Perkins part no is 2641808 is the lift pump fitted to my D3.152 and if you have no luck try DIPERK at Peterborough cheers, Steve Link to comment Share on other sites More sharing options...
