Fuel__2001 Posted April 20, 2008 Report Share Posted April 20, 2008 Im sure ive seen a thread on here before where someone used an oem/bosch glow plug for the eberspacher. However i cant find the thread. From memory, apparently the only difference between an eberspacher and bosch glow plug was eberspacher wasnt stamped on the glow plug. Has anybody used an oem glow plug or no where i could get one from? Thanks John Link to comment Share on other sites More sharing options...
Gary Peacock Posted April 20, 2008 Report Share Posted April 20, 2008 Try using this HERE to search the forum for it. Link to comment Share on other sites More sharing options...
smileypete Posted April 20, 2008 Report Share Posted April 20, 2008 (edited) Im sure ive seen a thread on here before where someone used an oem/bosch glow plug for the eberspacher. However i cant find the thread. From memory, apparently the only difference between an eberspacher and bosch glow plug was eberspacher wasnt stamped on the glow plug. Has anybody used an oem glow plug or no where i could get one from? Here it is, it's a 'Beru' plug #GH001 or '0 100 226 340' http://www.canalworld.net/forums/index.php?showtopic=10099 A local motor factors or VW garage may be able to source one, or google the above numbers. cheers, Pete. Edited April 20, 2008 by smileypete Link to comment Share on other sites More sharing options...
Fuel__2001 Posted April 20, 2008 Author Report Share Posted April 20, 2008 thats great, mine is for a hydronic 10 which i think is beru 'gv' type glow plug. will let you no how i get on Link to comment Share on other sites More sharing options...
Fuel__2001 Posted April 21, 2008 Author Report Share Posted April 21, 2008 Well im convinced that beru make this plug as it has there name stamped on it. The nearest ive come to finding a glow plug for a hydronic 10 is the 24v version 'beru gh009'. So i do think that at least im on the right lines as the code on the beru site correspondes to the eberspacher codes for the 24v glow plug. Now it would be great if i could find the 12v version Link to comment Share on other sites More sharing options...
smileypete Posted April 21, 2008 Report Share Posted April 21, 2008 Well im convinced that beru make this plug as it has there name stamped on it. The nearest ive come to finding a glow plug for a hydronic 10 is the 24v version 'beru gh009'. So i do think that at least im on the right lines as the code on the beru site correspondes to the eberspacher codes for the 24v glow plug. Now it would be great if i could find the 12v version Try the Dutch Barge mailing list, (PM 'idleness'/Julian) they might be able to help. Or there's a web page here with some pics details of Beru plugs on: http://www.e-cat.cz/c-999400_180832/podle-...e=4&sort=2a Or you might be able to get a catalogue CD from Beru themselves. cheers, Pete. Link to comment Share on other sites More sharing options...
Fuel__2001 Posted April 25, 2008 Author Report Share Posted April 25, 2008 Well i emailed beru about a glow plug for a 12v hydronic 10 and this is the reply i got back, "the part number you are asking for 0100321101 GV951 is not any long in our range. There is no replacement therefore. Sorry. " Strange as i managed to get one from eberspacher the other day, and you can get a plug from beru for the 24v hydronic 10. The closest match i can find is the GH001, as this is the only other 8v plug that beru make and fits into other hydronic models and is the same thread size. Link to comment Share on other sites More sharing options...
larkshall Posted April 25, 2008 Report Share Posted April 25, 2008 Well i emailed beru about a glow plug for a 12v hydronic 10 and this is the reply i got back, "the part number you are asking for 0100321101 GV951 is not any long in our range. There is no replacement therefore. Sorry. " Strange as i managed to get one from eberspacher the other day, and you can get a plug from beru for the 24v hydronic 10. The closest match i can find is the GH001, as this is the only other 8v plug that beru make and fits into other hydronic models and is the same thread size. Eperspracher could be old stock?, or have they changed supplier? Link to comment Share on other sites More sharing options...
Fuel__2001 Posted April 25, 2008 Author Report Share Posted April 25, 2008 Eperspracher could be old stock?, or have they changed supplier? probably brought a job lot some years ago and have a stock pile of these old type of plug. The box was all stamped up with eberspacher and the numbers on the plug matched those on the box, however the fitting instructions had the (GH001) newer looking plug. Link to comment Share on other sites More sharing options...
