kiwiSteve Posted February 2 Author Report Share Posted February 2 (edited) On 01/02/2024 at 09:25, GUMPY said: How will warm water and it will be warm effectively cool the reduction box? Ok... Ive been giving this a bit more thought... you do make a very valid point... so as Ive upgraded to a 3/4" fynspray pump @ 50LPM there should be ample water pressure to split off enough cold water to send down a 1/2" water pipe to cool the reduction gear and out via another outlet on the header pipe to sea... with the back pressure on the HX I probably won't even need a tap to dictate the flow. Well that gives me even more options to choose from... should be back up and running in a couple of days, now theres just the 50hrs run in time @ 1200 rpm... just as well we are not in to much of a hurry then eh.. Thanks for your help guys 😉 👍 Edited February 2 by kiwiSteve Link to comment Share on other sites More sharing options...
kiwiSteve Posted February 6 Author Report Share Posted February 6 (edited) Problem solved... thanks guys Edited February 6 by kiwiSteve Link to comment Share on other sites More sharing options...
Alan de Enfield Posted February 6 Report Share Posted February 6 You've remembered to 'double clip' on some of the hoses - don't forget the rest of them. Loss of cooling water = no engine. Link to comment Share on other sites More sharing options...
kiwiSteve Posted February 6 Author Report Share Posted February 6 yeah good spotting... it was 34c in the shade on the day I set her up and couldnt be bothered walking a couple of hundred yards to the chandlers to score a few more so robbed a few from here and there just to get her up and running for now, but your right I must get on to some replacements...thanks for the reminder... Link to comment Share on other sites More sharing options...
