How can I boost leisure alternator output whilst using Travelpower to charge ?
Bernie the Bolt
On 06/12/2023 at 10:31, nicknorman said:
As an aside to this I would just mention that you have to be quite careful with sustained high currents. It is very easy for something with a slight resistance to get very hot! Melted battery isolators etc!
I did not read the whole of the thread after this. Was it established that there are no battery isolators in this circuit under discussion?
4 hours ago, Bernie the Bolt said:
90 + amps - voltage = 13.1 ( just after starting b4 TP engaged )
44 amps - voltage = 13.7 ( after TP engaged )
10- 20 amps - voltage 13.85 tp 13.95
Either you are dropping a lot of voltage in the wiring, or the alternator is faulty. We need to know the voltage at the alternator terminals to distinguish between these two scenarios.
it was not established either way.
