AndrewV Posted September 26, 2023 Report Share Posted September 26, 2023 Hi! New to this forum and to engines. Trying to clean up wires and rewire BMC1.8 engine. Have positive wire from battery connected to solenoid, and negative - to starter motor (changed them to new ones) Do i need additional battery negative wire connection to engine block (ground)? (was not able to locate such wire). If yes, maybe someone can suggest - where it should be attached on engine? Link to comment Share on other sites More sharing options...
Tracy D'arth Posted September 26, 2023 Report Share Posted September 26, 2023 (edited) Any large bolt/nut on the engine block close to the starter motor, back to the battery negative terminals and to the hull close by on a separate bolt from the mains land line earth if there is one. Use 25mm2 cable as a minimum. 35mm2 better. Edited September 26, 2023 by Tracy D'arth Link to comment Share on other sites More sharing options...
Tony Brooks Posted September 27, 2023 Report Share Posted September 27, 2023 Often connected to an engine bed rather than the actual hull on a steel boat. Link to comment Share on other sites More sharing options...
AndrewV Posted September 27, 2023 Author Report Share Posted September 27, 2023 Thanks for hints! Will get proper size cables and will modify current wiring during next days. Link to comment Share on other sites More sharing options...
